86 3rd Brake light
Old Jan 5, 2005 | 11:07 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Default 86 3rd Brake light
Anyone have how 2 do it assistance on changing the 3rd brake kight on a 86? Have a friend with a blown bulb.
Thanks....
Old Jan 5, 2005 | 12:08 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
convertible - remove the rear license plate and reach in.
coupe - open the rear hatch, there are two screws (torx?) that will remove the brake light housing. There are four small bulbs inside.
Old Jan 5, 2005 | 12:24 PM
Chest-nut's Avatar
Chest-nut
Default 86 3rd Brake Light
If all 4 bulbs are out I seriously doubt that you have a bulb problem. Sounds more like a lack of 12v to the lamp assembly.
Old Jan 5, 2005 | 01:50 PM
sniperdiver37's Avatar
sniperdiver37
On my 88 all 4 were out or were out when I got the car. and they are not cheap. I think about 7-8.00 per. you need 4. I only put 2 in for now.
You will need to remove the 2 hex bolts from inside the hatch, then pry up the light from outside (it might be hard being it's been a few years since the last time it was off) then I think thier is 2 screws, not sure. then just pull out and replace all 4. DO NOT TOUCH THEM WITH YOUR FINGERS. use gloves or what ever.
Old Jan 5, 2005 | 01:55 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Thanks guys! Guess I'll tackle that this weekend. Appreciate the info..
Old Jan 5, 2005 | 02:33 PM
proemtpff's Avatar
proemtpff
I'm needing to change a few of my bulbs also.....so thanks!
Old Jan 5, 2005 | 10:24 PM
vader86's Avatar
vader86
If replacing the bulbs does not work, you'll either have to change the switch at the brake pedal, or replace the connector thats inside the B-pillar.
To 86 3rd Brake light
