push rods
Old Jan 7, 2005 | 07:57 PM
devilfish's Avatar
devilfish
Default push rods
What can happen if you dont run with "perfekt" push rod lenght? What will wear down ?
Old Jan 7, 2005 | 08:20 PM
JackDidley's Avatar
JackDidley
Tips of the valve stem can wear on the edge or if the pushrods are too short rockers will rub the valve keeper.
Old Jan 7, 2005 | 08:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the length is off the rocker will ride more to one side than across the center of the valve stem tip. This can cause excessive side thrust which can wear the valve guides.
Old Jan 7, 2005 | 08:50 PM
Corvette0096's Avatar
Corvette0096
Old Jan 7, 2005 | 09:17 PM
cv67's Avatar
cv67
St. Jude Donor '05
Someone just give you a set of pushrods?
Make sure and have the length and straightness checked!
Old Jan 8, 2005 | 06:09 AM
devilfish's Avatar
devilfish
No. Im just trying to learn things.
WHat is the procedure to measure the correct lenght?
Old Jan 8, 2005 | 09:01 AM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Get yourself an adjustable pushrod , Comp Cams make different sized ones depending on your application. What you want is the roller rocker tip to travel from the inner part of the stem (not the egde) to the outer part of the valve stem ( not the edge)! You want max lift to be right about the center of the stem! I lost my abiity to post pics but as soon as I get it back I'll post a pic!
Old Jan 8, 2005 | 09:58 AM
devilfish's Avatar
devilfish
Thank you!!
Old Jan 8, 2005 | 09:48 PM
ZD1's Avatar
ZD1
Hyd liftters can take .050" off.
Old Jan 9, 2005 | 03:44 PM
devilfish's Avatar
devilfish
any pics yet?
To push rods
