24# or 30# injectors
Old Jan 7, 2005 | 09:02 PM
mpick's Avatar
mpick
Default 24# or 30# injectors
I pesently have Bosch-Ford 24# injectors and need to replace at least one so I amgoing to replace all of the with injectors from New Era Performanmce.
I can't decide whether to change to 30# injectors or not
If I do will I need a new chip and what does it do to perfromance and gas mileage?
Old Jan 7, 2005 | 09:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
Stick with 24s. 30 is way too much injector.
Old Jan 7, 2005 | 09:27 PM
chriswtx's Avatar
chriswtx
30lb injectors are way to big. Stick with the 24lb...
Old Jan 7, 2005 | 10:26 PM
vader86's Avatar
vader86
24s, 30 is too big.
Old Jan 7, 2005 | 10:35 PM
mpick's Avatar
mpick
OK then which 24# should I buy
Lucas
Bosch
Accel
Old Jan 7, 2005 | 10:44 PM
chriswtx's Avatar
chriswtx
Bosch or Accel or FMS injectors. I bought a matched set for Accel injectors from Summinracing for $228 or so. They work great.
Old Jan 7, 2005 | 10:55 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I bought accel's two years ago I hated them the car ran like crap I sold them on ebay a week later and put my stockers back in. I just put in the Ford #24's from Jegs and the car runs great. They were $218 and I had them in a day.
Old Jan 7, 2005 | 11:11 PM
FD2BLK's Avatar
FD2BLK
Either will work but unless you want to reporgram the chip just stick the same size as the stockers back in.
Old Jan 7, 2005 | 11:19 PM
#70SM2's Avatar
#70SM2
Lucas
Bosch
Accel
I went with Bosch a couple years ago, cost more, but was like getting a new motor!
Old Jan 8, 2005 | 01:53 PM
vader86's Avatar
vader86
Get the Ford injectors
Old Jan 8, 2005 | 02:02 PM
sniperdiver37's Avatar
sniperdiver37
I went through this about a week ago on this forum and will end up sending mine to get rebuildt at cruzinperformance. But I guess in 88 they had realy good injectors. It's going to cost only about 100.00 for a perfict match set.Nice guy very helpful. Make sure thats the problem first.
But I was told also to use the ford #24 and no reprogaming needed unless to go 26-30 range.
Good luck, Jeff
To 24# or 30# injectors
