LS1 injectors installed!!!
Old Jan 10, 2005 | 10:20 AM
AS84's Avatar
AS84
Are the injectors the exact same height as my L98's. The way my fuel rails are setup I couldn't have any height variation.
Old Jan 10, 2005 | 12:27 PM
crheinish's Avatar
crheinish
Originally Posted by USAsOnlyWay
So is that a yes or a no?
It is a No, many run LS1 injectors in L98s without the clips and have no issue. My feeling is the clips are there for a reason use them.
Old Jan 10, 2005 | 12:29 PM
crheinish's Avatar
crheinish
No, they are a tad shorter. If you are running the factory TPI they will fit with no problem. Here is a pic with them installed in an L98 car.
Old Jan 10, 2005 | 01:26 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Yes I agree, I was just pulling your chain. I obviously agree, the last thing I want is fuel everywhere!
Old Jan 10, 2005 | 04:16 PM
1996man's Avatar
1996man
so would LS1 injectors be a nice upgrade for a LT4 if mine are starting to go bad?
Old Jan 10, 2005 | 04:21 PM
crheinish's Avatar
crheinish
An upgrade no, LT4 injectors are 28lb/hr @ 3 Bar.
Old Jan 10, 2005 | 04:25 PM
1996man's Avatar
1996man
what would a good upgrade to a moderatly modded LT4 be? 30lb injectors?
Old Jan 11, 2005 | 12:28 PM
crheinish's Avatar
crheinish
Originally Posted by 96BLKTN
94-96 are 26lb @43.5 PSI..... Why does nobody know this??
They are 26lb injectors when tested @ 3.5 Bar (50.75psi) but @ 3 Bar (43.5psi) they are 24lb. They are testing the same injector but @ a higher pressure. The LT4 injector is a perfect example of this.
Old Jan 11, 2005 | 12:32 PM
crheinish's Avatar
crheinish
To properly size injectors you will need to know 2 things Horsepower and B.S.F.C. Here is a link that should help:http://www.rceng.com/technical.htm
Old Jan 13, 2005 | 11:27 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
The clips prevent the fuel injector from getting ripped off the rail in the event of an accident. Most people don't bother with them as many HP injectors do not have a compatible groove.
The physical dimesions of the Bosch EV6 / LS1 injector are listed in our ad here: http://www.racetronix.com/12561462RFM.html
Most of our ads list injector dimesions.
Old Jan 13, 2005 | 11:28 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
These work well in a lightly modified LT1:
http://www.racetronix.com/621020.html
These work well in a lightly modified LT4:
http://www.racetronix.com/621037.html
Old Jan 14, 2005 | 03:14 AM
63redcoupe's Avatar
63redcoupe
[QUOTE=Racetronix]The clips prevent the fuel injector from getting ripped off the rail in the event of an accident.
.....That has to be the most hilarious reason I have ever heard for the injector clips. If the vehicle was in an accident serious enough to break the bolts that hold the fuel rail to the manifold, the last thing anyone would have to worry about would be the clips preventing the injectors from being "ripped" off the rail.
The actual reason for the clips was to retain the injectors in the rail during the engine assembly at the engine plant. They simply positioned and held the injectors in the rail. This allowed the rail and injectors to be easily handled and installed by the engine assembly line workers. How do I know this you ask???.....I toured the engine plant when the TPI and LT1 engines were being assembled and saw it first hand.
As for needing them when using injectors other than the originals, I personally would want to use the clips for the same reason. They would aid in the installation of the rail/injector assembly and would also "lock" the injectors in the correct position preventing them from pushing too far into the rail or into the manifold.
Old Jan 14, 2005 | 04:02 AM
USAsOnlyWay
Wow, cool info!
I'll still do it cause for some reason I don't want to be a flameball!
Old Jan 14, 2005 | 04:08 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
[QUOTE=63redcoupe]
You are correct in that the clips can help locate the injectors from top to bottom but in many cases there is little play for the injector to move up and down. In some cases the clip does not allow for proper alignment.
Many replacement injectors out there do not have slots located in the proper location in order to use the factory clips. In many instances people do not bother to use them.
The safety functionality is correct according to Delphi and we have no reason to disbelieve them. We will point out there there are many redundant fasteners in a vehicles fuel system to prevent lines from disconnecting and shearing during impact. Since an injector is basically floating the only anchor point it would have to maintain a seal on the pressure side are the clips.
FYI this past summer we did see a car with front end damage and the fuel rail had been lifted off one side of the manifold BUT the injectors were still hanging off of the fuel rail intact. If they had come off and fuel started pouring onto the hot exhaust manifold the car might had burst into flames.
Either way we are not going to turn this into a debate. Everybody can decide for themselves if retaining the clips is a priority to them.
The Delphi disc injectors have more than enough plastic around their inlets. This will allow additional groves to be cut if the ones provided by the factory do not align properly. There are many more unique applications than there are unique HP injectors.
Old Apr 30, 2005 | 04:10 PM
crheinish's Avatar
crheinish
what the heck happened to my thread?
To LS1 injectors installed!!!
