Help with Headlight Issue Diagnosis ('95 coupe)
Old Jan 10, 2005 | 01:20 PM
kspurr's Avatar
kspurr
Originally Posted by SPEED750
Need more info on the problem. Are you saying the drivers light goes completely open and closed on its own? Our does it just flop in the breeze?
The driver's side headlight goes completely up and down and works as it should. The passenger side headlight comes on but the motor never gets power to move up or down.
Old Jan 10, 2005 | 01:22 PM
kspurr's Avatar
kspurr
Hooked on Vettes and gramercyjam, thanks for the input. I'll definitley check out that fuse and look into checking the wire when I get home from work tonight. I'm hoping that one of those turns out to be the culprit as I'd rather not have to look into getting a third headlight control module...
Thanks!
