long tube headers & cam
Old Jan 10, 2005 | 10:49 AM
jerrys 1989's Avatar
jerrys 1989
ok thanks for replys
with the headers i will need a collecters and a new y pipe would like to go true dual all the way back . as for the gears set just like the sound they make theres no way to trick the knock sensor so i can use one ? and for the cam will the comp cam work with a stock chip
Old Jan 10, 2005 | 11:44 AM
mikey whipreck's Avatar
mikey whipreck
I strongly recommend Hedmans on Summit's page, for an L98 you may want to consider 1 5/8" primaries... They have hedders both with and without emmisions provisions, and also can be ceramic coated.
You can easily get around the knock sensor, without throwing any codes...
To eliminate the knock sensor (as to CFI-EFI's procedure), if you remove the blue no. 5 wire from the ESC module, you'll eliminate the knock sensor
If you thinking about true duals... and you will have LT headers on. Check the FS/T section of this page. Often you'll be able to find a stock LT1/4 exhaust for next to nothing (or even FREE!)... Get a muffler shop to weld it on, and you have yourself true duals.
Old Jan 10, 2005 | 12:05 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
You can get headers and cams from almost anywhere. Jegs, Summit, TPIS, SDPC, Lingenfelter, SLP... the list goes on and on.
As for the gear drive, the knock sensor will pick up on the vibration and gear mesh noise and retard timing thus nulifying any gain that you would have gotten. This was proven by Car Craft back in 2000... but also disproven by Super Chevy (I think) later on... I personally wouldn't use it.
Old Jan 10, 2005 | 12:11 PM
redbullapril23's Avatar
redbullapril23
Hedmans are the cheapest!
get them uncoated And I can ceramic coat them Inside and out, 3 yr warranty, limited life time rust/corrosion warranty, and all preping included for $188 !!!!!!!
just let me know
thanks alot your friend
Sean
Slimshaby@mindspring.com
Old Jan 10, 2005 | 12:23 PM
cv67's Avatar
cv67
St. Jude Donor '05
Gear drives aren't worth the hassle. You'll get sick and tired of the noise after a while, and the harmonic vibrations they put out are'nt good for the valvesprings and bearings. But, if its what you want, go for it. Make sure and research the knock sensor bit as well. If you disable it, you may not hear it pinging over the geardrive: If it's left intact ,like an above post said, it'll just retard your timing. Different strokes for different folks!
Old Jan 10, 2005 | 01:37 PM
crheinish's Avatar
crheinish
Originally Posted by jerrys 1989
where can i find long tube headers for a 1989 L98 corvette also would like to go larger on the cam & put a gear drive in . wont to increase hp but also be able to take road trips . also been reading that the gear drives wont work with a knock senser is there any way around that ? need some input & help .
Hooker Headers from Summit or Jegs 2149 for smog 2151 no smog. Cam Lingenfelter 74211 with a 1.6 RR. Skip the gear drive.
Old Jan 10, 2005 | 05:15 PM
jerrys 1989
ok all i gess the gear drive is out
Old Jan 10, 2005 | 08:11 PM
redvette6spd's Avatar
redvette6spd
Old Jan 10, 2005 | 09:22 PM
jerrys 1989
Originally Posted by redvette6spd
Old Jan 11, 2005 | 10:06 AM
jerrys 1989
ttt
Old Jan 11, 2005 | 07:54 PM
jerrys 1989
ok all thanks for your input & info . how about new lifters . need them or not ?
thanks again
Old Jan 16, 2005 | 03:04 PM
jerrys 1989
bump
Old Jan 16, 2005 | 03:15 PM
Nathan Plemons's Avatar
Nathan Plemons
How many miles are on it now? Roller lifters don't really wear all that much so you probably don't NEED new ones, but they'll never hurt.
I like the comp cams pro magnum's.
Old Jan 16, 2005 | 11:12 PM
jerrys 1989
just pulled cam today engine has 127000 on it cam and lifters look like new getting ready to strip down for a complete rebuild. any input would be helpful
Old Jan 17, 2005 | 12:40 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I just put the ceramic coated Hooker super competition 2149's on my 1990 last week with the hooker Y pipe. Here's the threads I had showing them off in c4 general. http://forums.corvetteforum.com/showthread.php?t=990504
They were $549 at summit and man do they sound and make it run good!
Old Jan 22, 2005 | 02:24 PM
jerrys 1989
Originally Posted by 89 Paul in Cal
Are looking to retain emission tubing on the headers?
Hooker 2149's. Jeg's or summit.
I have a used Crane compucam from my 89 I'd like to sell.
it's pn#104224 I think they also call it a 2032 grind.
214/220
.452 .465
112LSA
as you know, hydraulic rollers don't hardly wear and this one is in very good shape. Will wake up the motor nice and still meet smog test requirements.
$100.00 bux + shp
sorry for the blatant plug. :o
will this cam work good with stock heads pistons also what if i put 1.6 rockers on will i have a probleam with valve to piston contact ??
Old Jan 23, 2005 | 02:21 AM
jerrys 1989
bump
To long tube headers & cam
Old Jan 23, 2005 | 08:57 AM
mean8t's Avatar
mean8t
How much Hp and TQ are you wanting to get? Are you still going to be using all the stock intake components? I personally am very partial to Comp Cams XE line of cams they have more lift for the same duration. If you were going with a new cam and depending on your intake mods I would go with either the
XE269HR 218*/224* @.050 and .495"/.503" 112 LSA this is a good profile with more lift with 1.5 rr's than the afore mentioned cam with 1.6 rr's.
If you go with aftermarket runners, base and ported heads I would go with the XE276HR 224*/230* @.050 .503"/.510" This is the roller version of the cam that I run it idles nice and makes great power.
If you are on a budget then the aforementioned cam is also a good profile, just not one that I would buy new.
JMHO
Old Jan 23, 2005 | 09:24 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I don't think I'd put a gear drive in anything. I'd go with a good double roller chain or if it was all out performance and adjustability I'd put a belt drive on it.
Old Feb 1, 2005 | 10:08 AM
jerrys 1989
ttt
