Brake rotor hat covers
Old Jan 9, 2005 | 09:48 AM
Tom Piper's Avatar
Tom Piper
Default Brake rotor hat covers
I know there are brake rotor "hat" covers for the C5.
I have the C5 brakes on the front of my '92 C4.
I would like to get a set of matching brake rotor "hat" covers that will do the front C5 brakes and the rear '92 C4 brakes.
Do these exist?
Tom Piper
Old Jan 9, 2005 | 10:15 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I've seen the C5 covers and thought "what a classic example of form over function."
Install these puppies and you add unsprung weight and hinder brake cooling at the same time....all in the quest to look pretty.
Just paint the unswept area of your rotors....works just as well.
Larry
code5coupe
Old Jan 9, 2005 | 10:25 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Larry
code5coupe
Spoken like a true "performance first" guy!
Old Jan 9, 2005 | 11:32 AM
gcrouse's Avatar
gcrouse
If you're after looks AND performance, the Baer Eradispeeds come in a 2 piece, with real aluminum hats bolted to slotted and/or drilled rotors. TByrne has them on sale...
Old Jan 9, 2005 | 05:59 PM
Tom Piper's Avatar
Tom Piper
Larry
code5coupe
The "hat" covers that are sold for the C5 are made of very thin sheet aluminum that are powder coated -- can't add much weight. My guess is the powder coating weighs more than the aluminum.
I talked to AO Engineering about the ones they make for the C5. The engineer told me the rear C5 hat cover would fit the rear '92 C4 rotor if it had the edge trimmed slightly. But, he said the aluminum material is soooooo thin that the only way to trim it is to put it in a wax material to stiffen it and belt sand it away.
I painted the center of my rotors about a year ago with high temp paint -- it just doesn't hold up, they don't look good after a year.
My guess is the six coats of paint I put on them weighs more than the hat covers. And, since the hat covers are sandwiched between the hub and wheel with 100 lb ft of torque on the lug nuts, the heat will be pulled away easily just like the hub heat is now. The hub covers don't touch the swept area of the rotor or impede the air flow through the rotor fins.
Tom Piper
To Brake rotor hat covers
