3 seemingly random questions...
Old Jan 10, 2005 | 11:43 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by eschoendorff
Huh! I thought that #2 was a kinda dumb question, but now I'm glad I asked. Thanks guys.
That is an interesting comment, because no one has addressed #2.
#1.) Good advice, so far. You can use generic heater hose for long, straight runs. Most heater hose seems to be 5/8ths". A typical heater uses 5/8th" and 3/4". Hose is measured by the I.D. so you can measure the fitting, O.D. it came off of for an accurate size.
#2.) A good, medium pressure oil hose works for trans coolers. MOST pros will use that. When *I* connect a hose to metal tubing, I like to start a double flair in the tubing to raise a ridge on the tubing. With the hose clamp beyond the ridge, it will never come off. Stainless steel braided hose with the proper fittings make for a "bullet proof" installation.
#3.) An air ratchet is NOT an impact tool. Standard sockets are fine.
RACE ON!!!
Old Jan 10, 2005 | 12:10 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by CFI-EFI
#3.) An air ratchet is NOT an impact tool. Standard sockets are fine.RACE ON!!!
Larry
code5coupe
Old Jan 10, 2005 | 01:00 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Summit has an assortment of Tranny coolers
www.summitracing.com
Old Jan 10, 2005 | 03:25 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Thanks for the replies, everyone. I know that they were elementary questions, but I'd rather ask and look stupid than simply do and be poor(er).
CFI... you can tell that I have'nt been getting much sleep lately, huh???
-Ed
Old Jan 10, 2005 | 07:47 PM
CFI-EFI's Avatar
CFI-EFI
-Ed
RACE ON!!!
Old Jan 10, 2005 | 08:18 PM
tempest's Avatar
tempest
question - so does the hose size signify the size of the fitting it goes around or the hose's ID prior to installation? i would expect the pre-install ID would be an 1/8 or so smaller than after installation...
Old Jan 10, 2005 | 08:38 PM
CFI-EFI's Avatar
CFI-EFI
Pretty much, both. Measure the fitting behind the barb or raised part on the end that keeps the hose and/or clamp from sliding off.
RACE ON!!!
To 3 seemingly random questions...
