Spicer U-joint part numbers?
Old Jan 10, 2005 | 03:10 PM
LPDesRoche's Avatar
LPDesRoche
Vader, I just did a search of your recent threads and nothing came up. I know there was just recently a thread about this. I don't need Toms part numbers, I need the actual spicer numbers. I rather just get the parts from my local Spicer supplier, but I also want to have the numbers with me when I get there. I hate to have them order the wrong parts for me.
So again....does anyone know the actual Spicer part numbers for the U-joints. Both driveshaft and half shaft would be helpful.
Lee
Old Jan 10, 2005 | 05:56 PM
VMAX451's Avatar
VMAX451
Half shaft = SPL30-2X
Drive shaft = 5-786X
Old Jan 10, 2005 | 08:43 PM
LPDesRoche's Avatar
LPDesRoche
Thank you.... I will head to the local dist. tomorrow.
Lee
Old Jan 11, 2005 | 03:13 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Originally Posted by Corvette Kid NC
Half shafts 5-800X
Drive shaft 5-786X
Corvette Kid NC is correct. Those are the Spicer numbers you want to use. I contacted Spicer directly myself when I did my half-shafts and those are the new Spicer numbers. There are a couple of u-joints that fit the C4 Vette, but for the half-shafts the 5-800X is the heavy duty, no zerk fitting, aluminum cap unit. The SPL30-2X number may refer to the same u-joint with steel caps. Spicer recommends applying anti-seize when using the steel cap u-joints with the aluminum half-shaft of the Corvette. According to the Spicer Tech I spoke with he 5-800X was made specifically for the Corvette and does not require the use of anti-seize on the caps as they are anodized aluminum.
Old Jan 11, 2005 | 03:59 PM
VMAX451's Avatar
VMAX451
According to Tom's Differentials, SPL30-2X is specified for aluminum shafts. It is also cold forged and has no zerk. I don't know what is different about 5-800X, but apparently both are correct and should work.
Old Jan 11, 2005 | 07:06 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I can't say for sure but someone here on the forum once stated that the SPL30-2X was an equivilant to the 5-800X that was recommended for the outer side of the half-shafts in extreme applications. I never could determine for sure if they were coated like the standards. BTW, if memory serves, the coating is called Endurion, or something close. And they are meant to be installed as is, with no anti-seize. I believe the caps are steel in either instance but I can check this evening to be sure.
Yes, the caps on my 5-800X are definitely steel.
Old Jan 11, 2005 | 08:48 PM
Sawbone's Avatar
Sawbone
I seem to remember the SPL30-2X was a heavy duty version of the 5-800X, but I'm not positive. Either one should work.
To Spicer U-joint part numbers?
