9inch ford is on the way
i know theres few people on the forum that put a 9 inch in the car , i cant remeber who . what do you guys think , and yeah my Dana 44 should be up for sale very soon
and now if my car goes slow i can blame it on the ford parts
This is a MAJOR MAJOR undertaking that needs to be done RIGHT, or you will be getting taken to the undertakers.
Remember this is what is holding the entire rear of your car in and under the car. Most of the MAJOR wrecks you see on the strip are caused by something letting loose and causing the driver to loose control.
I would NEVER think about doing this to my car, unless it was in the hands of a VERY skilled individual. 120+ MPH and having the rear **** sideways is not a good thought. Or worse yet on the street coming around the corning into oncoming traffic.
Please use caution and make sure your doing it all RIGHT.
Would hate to see something nasty happen. i know theres few people on the forum that put a 9 inch in the car , i cant remeber who . what do you guys think , and yeah my Dana 44 should be up for sale very soon
why a 9 inch?
-Jeb
A four link resists independent movement (vertical) of the wheels. Both wheels want to move up and down together in other words.
If I think about the geometry and forces involved in both, I certainly need an explanation of why a four link is better for the street.
Rarely do I ever see a street driven car with a four link unless it's driven really infrequently.
EDIT... doing some reading after posting this it does seem most chassis manufactures say a four link is better for the street. I still can't see why though? Enlighten me.
Would hate to see something nasty happen. A four link resists independent movement (vertical) of the wheels. Both wheels want to move up and down together in other words.
Both are a live axle design.
After talking about it with some local race car smart people, they advised against it money wise, time wise, saftey wise, etc.
One suggestion was to just buy a tube frame drag car a slap a vette body on it. Easier, safer and costs only a little more.
The other was to look in the back on National dragster for a backhalfed vette around the year/model I want in the for sale section.
after a few months bingo! an '88 vette back-halfed a certified to to 7.5 sec's. The sale price was cheaper than doing it to my car from scratch!
Just drop a motor in it - came with trans.
I never bought it. But I know what to do in the future should that urge come again.
Mt two cents.
Matt383
Here's some fundamental differences:
4-links are infinitely adjustable. You can completely move the instant center around ANYWHERE you want it. They have more pivot points which is what you want in a street car, in other words they offer better articulation of the chassis.
Ladder bars are fixed length, which means other than moving the instant center up and down you cannot move it forward or backwards. You can change the tire contact this way but no other adjustability. Ladder bars tend to be a lot more violent on launch as well. And, they do not have the pivot points or articulation that a 4-link offers. They are also longer and more difficult to package. But they are less expensive and simpler to set up (because of their given "less adjustability").
-Jeb
-Jeb
Yes, you need a track locator device, whether it's a diagonal link (between front eyelet on one side and rear eyelet on the other), a Panhard Rod (brace between a fixed point on the chassis - hard to find on a Vette with stock frame -and the axle housing itself), or a wishbone (best method - fixed point in front to both axle tubes or two sides of the center section).
As to 4-link adjustments.... being I'm a drag racer as well as a shop owner, I can tell you in a nutshell : there are 1001 points of adjustment, with only about 4 that work on a 4-link... very easy to get lost, and NOT something for the novice!
Ladder bars are VERY violent (have this setup on my 9 sec. Chevelle), but are easy to tune. Easy to set up in the car.
Now..as to feasability and price: Are you quite ready to spend, oh say about $10,000 or so on this car? (this is a kind estimate) The rearend alone will set you back at least 3K by itself, plus the cost of suspension parts, brake, etc (you can reuse your stock brakes if you're handy with a lathe and mill) and the back-half frame rails to do the job properly. Not to mention the labor costs involved (this is NO PLACE for a "as long as I buy the beer for my buddy" type deal) for a professional shop to do the work. Plus, consider that rod ends are a consumable item (both 4-link and ladder bar), and good 4130 ends are nearly $200 EACH (that's 8 for a 4-link and 6 for a ladder bar setup), which you have to replace on a yearly basis at the minimum. You'll also DESTROY any semblance of street manners (goodbye cornering above 20 MPH), and of course, the ride quality will suffer. I could go on and on....
Remember this: a street and strip car will do neither as well as purpose built cars - race cars are designed for the track, street cars are designed for the street...simply put, get a purpose built car, or stay at your current power level. Good luck in whatever you decide to do.
tubs and 15x33s are in the picture
