I've noticed a lot of you are running the FelPro 1094 shim gaskets with aluminum heads.
A lot of you say not to run this gasket with aluminum heads due to electrolysis.
Can we have a check in on this again?
I'm ready to order up a couple of sets of them for some engines I'm building.
The pistons are already .022 in the hole and I'd like to use them to get the quench down as well as possible.
OOPS! It's a 1003, not 1053. .41 compressed thickness. Fel Pro also makes a 1014, at .38. Someone correct me if I'm wrong. These are for 350 Chavy w/aluminum/Iron heads. Will not work on the LT1. Hope this helps
so are impala gaskets the way to go for more compression and more power on a lightly modified engine? its safe isnt it? have many guys done it? how much power does it add?
Need thinner gaskets.
I have used the steel shims on numerous engines with iron heads.
Never had any aluminum ones back in 'the day'.
Several folks on here are reporting running the 1094 which is the .015 thick steel shim gaskets WITH aluminum heads and are having no problems.
I'd just like to confirm that before ordering them up.
.041 I'm not going to be too happy with as I'm going to be right up against 10.5:1 compression anyway.
Sooooo , need to minimize the quench area.
i heard that impala gaskets bump up compression .3:1 so.... if your motor (LT1) is 10.5:1 stock then it should bump it up to 10.8:1! that would be a halfway decent increase in power i would think. mine is 10.8:1 stock so i would be at 11.1:1 with the gaskets. i hope that gives me as much power as it would seem like!
steel gaskets used with alum head is NOT reccommended.. NONONO...ok with cast heads... The Felpro Gasket # is 1010..which is slightly bigger than the bore...the gasket Kit H7733-PT9 contains PT-4 upgraded head gasket for alum installation
I remember a recent thread about this... The experts' opinions were that the bump in compression wouldn't be something you would be able to feel...a few HP at best. Of course, every little bit helps - but you're not going to see anything "noticeable". That's what I remember, anyway.
There was some pretty decent math to back it up, so I don't believe it was just somebody talkin' out their azz...
The rule of thumb is 4% increase in power for every FULL point of compression. So the .3 increase will give a little over 1%. BUT, the tighter squish will result in more efficient combustion and knock resistance to make it MORE than worth while. I wish I knew more about the compatibility of a steel gasket in a bi-metal engine. The first thing that occurs to me is, you use steel bolt that contacts both the head and the block. Why not the gasket?
Call Cometic, they are not cheap but you can go down to. 027 maybe less depending on the bore ID and they have a silicone coating on them, supposedly reuseable too
I was thinking the same thing.... Steel Bolts, Aluminum heads...
That "should" keep everything at the same potential as far as galvanic activity is concerned.
Another thought is the steel shims are a lot harder (are they?) than the aluminum head. Will this cause a thing called brinnelling (sp) ?
I'd like to get squish right but don't want to sacrifice a good set of heads to find out if these gaskets will work.
Come on in guys, I know there's some of you out there running them 'cause I did a search on it and FOUND YOU!!
Come on and check in here and let is all know about your experience with those gaskets.
I just checked the gasket that came off a standard iron head L98 and it's a composite .047 thick gasket.
Guess quench doesn't matter much when you're running 8:1 compression
I used to spray them up with aluminum paint to help the sealing.
Never had any problems using them with iron heads.
They were 'the' gasket to use in HP applications.
I did use the copper SCE .021" on one engine, sprayed them with the copper gasket sealer/adhesive and put them on, started the engine and got it up to temp for @ 15 minutes, then let it cool back down and retorqued the heads, no problems.
