Header Bolts
Old Jan 10, 2005 | 08:50 PM
LT4BUD's Avatar
LT4BUD
Default Header Bolts
Stage 8 for my Exotic Muscle long tubes??
8911------3/8-16x3/4
8911A-----3/8-16x1
Are these the ones......use 1"???
http://www.stage8.com/AutomotiveStart.htm
Do the click here for close up view...
Learning something new......I thought people were talking about a Grade 8 bolt......
Do I finally have it figured out??
Best place to buy??
Old Jan 10, 2005 | 08:53 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Yes the 1" ones will work
Old Jan 10, 2005 | 08:59 PM
MaxLean's Avatar
MaxLean
Stage 8's are a PITA. What I use are Mr. Gasket header bolts with a reduced hex of 3/8" instead of the normal header bolt that has a 7/16" head. I also use their special header bolt lock washers. With this combo, I can easily get a 1/4" drive socket on ALL the bolts on my '94 and have NEVER had a bolt back out or had an exhaust leak in the nine years that I've had them. And that's with having them off and on more times than I can count (for performance work, not because they were leaking).
Old Jan 10, 2005 | 09:00 PM
ABNVET.I's Avatar
ABNVET.I
They are great. I use them and you dont have them backing out on you.
Old Jan 10, 2005 | 09:07 PM
CFI-EFI's Avatar
CFI-EFI
It is a good idea to retighten after the first half dozen or so heat cycles. The bolts loosen from the gaskets being compressed and taking a "set". Even Stage 8's can't prevent that.
RACE ON!!!
Old Jan 10, 2005 | 10:28 PM
eguyett1985's Avatar
eguyett1985
I use the ARP stainless header bolts. They have a 5/16" head so it's easy to get a wrench on them and they won't rust due to the thermo cycling like a standard header bolt...just make sure to retighten them a few times after the engine runs and cools off...sets the gaskets then you won't have a problem.
Old Jan 10, 2005 | 10:34 PM
LT4BUD's Avatar
LT4BUD
Originally Posted by eguyett1985
I use the ARP stainless header bolts. .
Aren't the Stage8 stainless????
Old Jan 10, 2005 | 10:38 PM
eguyett1985
All the ones I've ever seen including the set I put on my JBA headers on my TBI Blazer were cad plated steel...the concept is pretty good but I wouldn't use them on Corvette headers that don't have alot of room to get to the bolt..I like the ARP reduced head size so much better...just my opinion though..
Old Jan 10, 2005 | 10:43 PM
LT4BUD's Avatar
LT4BUD
Cool demo....
Old Jan 10, 2005 | 11:05 PM
JCAIRE2's Avatar
JCAIRE2
I like header studs, easier to work with.
Old Jan 11, 2005 | 06:51 AM
LT4BUD's Avatar
LT4BUD
What I really am after are the ones that Exotic Muscle sells for their long tube headers.......Merle said stainless
Again I thought at first he was talking " Grade 8"......now I am sure he did say "Stage8"...
Thought I would just pick them up locally at Summit and save shipping...
Old Jan 11, 2005 | 10:50 AM
1989redvette's Avatar
1989redvette
well ya better call first they were out of stock of the small head 1" stainless header bolts as of thursday.. and on back order till later this month ... i just ordered my header gaskets and such last weds and they told me this.. said they were not sure when they would have stock again ... good luck ..
Old Jan 11, 2005 | 12:35 PM
LT4BUD's Avatar
LT4BUD
I just talked to Summit and they have Stage8 P/N 8951 in stock....these are 3/8-16x1" 6pt, stainless steel...$69.95
Old Jan 11, 2005 | 02:20 PM
Perfusion's Avatar
Perfusion
That price (69.95) from Summit seems to be higher than the price I paid from Merle when I ordered my headers. IIRC, I paid 49.95 from EM. The only problem with the Stage 8s that my installation shop noted, was that the locks didn't always work "as is". Some had to be ground down to fit properly against the primary.
Old Jan 11, 2005 | 02:31 PM
CFI-EFI's Avatar
CFI-EFI
WOW!!! That's a lot of money to spend for bolts, when a $10.00-$15.00 set will do as well.
RACE ON!!!
Old Jan 11, 2005 | 02:46 PM
1989redvette
RACE ON!!!
no doubt i ordered my stainless 3/8 12 point by 1" for 14 bucks ... should be here today i ordered sat night...
are the stage 8 bolts the smaller 3/8 head??? i tried the standard 7/16 on my headers and they will not work to large in diameter..
Old Jan 11, 2005 | 03:33 PM
LT4BUD's Avatar
LT4BUD
RACE ON!!!
Geez I hate to waste money, but I want it to work the first time and hopefully last for years......
Plan on going with Felpro 1406 gaskets with Stage8 8951 ss bolts
I hope the "locking" feature of the Stage8's really work......
Is there really something for $10-15 that will really do the job, Bud screwed up again....I just ordered them for $62 from Powerhouse Performance.....
Perfusion, I wonder what the $49 ones were from EM, you are right, thats what Merle quoted me, plus shipping....do you have part number, were they ss or plated??
To Header Bolts
Old Jan 11, 2005 | 03:57 PM
Strick's Avatar
Strick
I used allen socket head S/S 1" bolts. With these I can even use a torque wrench on the bolts. Don't forget to use high temp anti-seize on the bolts. With the right torque, they don't seem to loosen.
Old Jan 11, 2005 | 04:39 PM
CFI-EFI's Avatar
CFI-EFI
I have no doubt the locking feature will work and keep the bolts from turning. But that doesn't mean they will stay tight. Go back to my opening post of this thread, #5, and reread.
Conventional header bolts will work just as well. Use the longest bolts that don't bottom out and keep them tight through the first half dozen heat cycles, or so and you'll be happier and richer.
RACE ON!!!
Old Jan 11, 2005 | 05:23 PM
#70SM2's Avatar
#70SM2
RACE ON!!!
I have a question along the same line as this thread, hope it's ok. My builder put Tight fit headers on my new motor without gaskets, just used the Right Stuff. But I still seem have some minor leaks at the headers, he told me that gaskets burn up. Does this sound right to you guys? I have the 23º TFS. heads. If not what gaskets to go with? Thanks.
