vented dist. cap?
Old Jan 12, 2005 | 05:32 AM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
Default vented dist. cap?
hello again! went to get my dist and cap kit cap kit 230.00 vented cap for 95-96 models 130.00 question is will the vented cap work on my 94 if so is there anything different i would have to do? i see the vented cap looks the same physically other than a small tube coming out the bottom which i am assuming is the vent. if this will work do you have to hook anything to that tube or does it just vent straight out that tube on the bottom? any help would be greatly appreciated
Old Jan 12, 2005 | 05:44 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Need a pic ?
Old Jan 12, 2005 | 06:11 AM
myvettesblue
St. Jude Donor '05
got the pic
Old Jan 12, 2005 | 06:16 AM
REDC4CORVETTE
If it were me I would run a vac hose to the top of the engine so water can't get into the vent hole.
The LT4 opti uses a vac hose conected to the intake to draw vaccum so the water does not stay in the dist.Look up the dyna spark dist .
Old Jan 12, 2005 | 06:29 AM
myvettesblue
St. Jude Donor '05
so it will work on my 94 then right?
Old Jan 12, 2005 | 06:55 AM
myvettesblue
St. Jude Donor '05
next question what tool do you need to remove the cap do you need a special tool smallest star socket i have is 4mm and it is to big thankyou
Old Jan 12, 2005 | 09:01 AM
comp's Avatar
comp
with vac. hose connected can't water be "sucked" into it when running ???
Old Jan 12, 2005 | 05:15 PM
C4Crazy787's Avatar
C4Crazy787
You will need to run the fresh air hose to the bottom 3 holes in the opti as-per this tip, http://www.corvettefever.com/howto/16758
Here's a pic of mine after I got done. http://www.digitalcorvettes.com/phot...optivent02.JPG
Old Jan 12, 2005 | 05:35 PM
C4Crazy787's Avatar
C4Crazy787
I went to the hardwarestore a picked up a star drive headed screw that fit the one on the opti.
Old Jan 12, 2005 | 06:11 PM
myvettesblue
St. Jude Donor '05
great idea! i will do that thanks for all the helpful information guys it is really appreciated
Old Jan 12, 2005 | 07:39 PM
VenkmanP's Avatar
VenkmanP
http://www.fierolt1.com/lt1_95_up_OptiReplace.htm
Old Jan 13, 2005 | 04:59 AM
myvettesblue
St. Jude Donor '05
Originally Posted by steve9899
thanks that was a good lesson there also
To vented dist. cap?
