Emission delete
Old Jan 12, 2005 | 10:34 PM
1fast91's Avatar
1fast91
Default Emission delete
pullin the motor on the vette right now and was wandering, i want all that emissions control **** gone. what am i gonna have to get to prevent from causing any problems.
Old Jan 12, 2005 | 10:45 PM
mikey whipreck's Avatar
mikey whipreck
If you just mean the AIR system and cats... it wont cause any codes to occur... I believe there is a tech tip on this page to delete the AIR system.
*waits patiently for Bogus to voice his opinion
Old Jan 13, 2005 | 01:33 AM
korvette4u's Avatar
korvette4u
yes you can remove all the emissions stuff, air valves, air pump(replace with air pump eliminator), egr (on intake blocked/plate, plug its supply line ) ), egr sensor, (Block/plate it too ). all vacuum lines that run to these units.. air valves in front of motor (just below tb),also remove vaccum line from passenger side vavle cover to TB, ( install air breather, plug TB), remove line just below it as well, plug off, remove air switch at thermostat housing, remove all small pipes connected to headers weld holes and port the insides or block off with cap( if you have no welder)ther should be no code 32 issues with a 160 thermostat.
some useful info http://www.geocities.com/jgkov/index.html also do a tech search
Old Jan 13, 2005 | 08:09 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
I don't understand why you want to do that. The engine was designed with all that stuff, and it uses a negligible amount of HP, and helps all of us to breathe easier.
Old Jan 13, 2005 | 09:09 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
We need an emoticon of a smiley choking on exhaust fumes
Old Jan 13, 2005 | 09:17 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Most likley you will need custom tuning for the ECM so it isn't looking for all that stuff. My Lt-1 did.
Old Jan 13, 2005 | 02:59 PM
SilverBeast
St. Jude Donor '05
Good one!!
To Emission delete
