Replace TPI with LT1 induction
Old Jan 13, 2005 | 04:50 PM
GeosFun's Avatar
GeosFun
Default Replace TPI with LT1 induction
Forgive me for this one. I know I have read some threads on this subject in the past but I cannot find them in the "Search" function. Does anyone know whether an LT1 induction can be substituted for the TPI (1988 model) and still pass the California "visual" during the bi-annual smog test? I heard that it might because it is OEM equipment and all the smog equip hooks up. I was under the empression I could not change induction systems unless they had an EO# or were available for the year car involved. Of course the LT1 induction came out several years later
If this is true, I want to know what is involved. Can you either (1) tell me what machining/modifications are involved, or (2) what to key in on the forum's search" function to find this discussion, or (3) does anyone make these LT1 conversions commercially available for TPI equipped engines?
Old Jan 13, 2005 | 04:54 PM
FD2BLK's Avatar
FD2BLK
wont pass inspection. The EGR has to be removed to get the distributor back there.
Old Jan 13, 2005 | 05:42 PM
comp's Avatar
comp
is it worth the switch ????
Old Jan 13, 2005 | 05:48 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
www.LT1intake.com go there for all the info I'm in the process of doing one now
Old Jan 13, 2005 | 08:03 PM
crheinish's Avatar
crheinish
Old Jan 14, 2005 | 08:23 AM
comp's Avatar
comp
it looks like it would be
Old Jan 14, 2005 | 09:38 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
I think its a really good idea for someone one a budget. Then you get some of the best of both worlds: No Opti with LT-1 intake. Probably could make pretty decent power with that setup.
Now, I'm gonna go back and play with my opti
Old Jan 14, 2005 | 11:41 AM
GeosFun's Avatar
GeosFun
Wow. Great website reference! Exactly what I was looking for, complete with a Pop Hot Rodding article on the swap, dyno tests, costs, FAQ's, everthing. I am a happy camper!
I am considering a 427 engine for daily driver/occasional drag strip passes in my '88. I am thinking the Mini-Ram would be the best for me, (low end torque should be a non-issue) but it has no EO# nor will it pass smog. But from the physical appearance of the LT1, I would think the two should produce quite similar torque signatures, particularly with some porting. So I want to explore this alternative.
Old Jan 14, 2005 | 11:48 AM
GeosFun's Avatar
GeosFun
Oops. Just read one of the FAQ. FD2BLK, you are right. NO EGR in order to make room for the distributor. Damn. Back to the drawing boards. Thanks, guys.
To Replace TPI with LT1 induction
