What ignition mods to do?
Old Jan 14, 2005 | 11:38 AM
boceltics17's Avatar
boceltics17
Default What ignition mods to do?
I bought an 86 that already had a bigger cam, ported heads, reworked base manifold, bigger tube runners, ported plentum, roller rockers, 52mm throttle body and headers. It did have a hotter coil in it and high performance control module, but they failed on my drive home from California and the shop that worked on it only had stock replacement pieces. I did not notice much difference with the stock pieces, but want to ensure I am getting all I can out of the motor.
Given these mods, what ignition set up should I be running?
I see that Corvette Central offers a Hypertech Power coil and an HEI control module. Are they worth their salt? Would I be in line for an MSD?
I don't know the cam specs, but it does have a nice lope to it.
Thanks for any help you can offer.
Old Jan 14, 2005 | 11:56 AM
cv67's Avatar
cv67
St. Jude Donor '05
I noticed no difference from aftermarket ignition pieces as compared to stock, especially the module. I did leave the MSD coil in. Goos wires always seem to be worth it.
I meant good wires.The goos wires are temperamental suckers
Old Jan 14, 2005 | 02:09 PM
JCAIRE2's Avatar
JCAIRE2
That's about it. An MSD box if you run nitrous or forced induction.
Old Jan 14, 2005 | 06:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For a NA application I prefer the HyperTech setup for simplicity, unity and reliability. Also it fires well to 6k RPM or more, whereas our stock HEI tends to fall off by 5k RPM.
Indeed a set of performance wires along with cut-back stock style AD Delco plugs gapped to say .045" will also help performance by assuring an efficient burn.
I run the TPIS performance wires for an improved stock size wire but MSD SuperConductor wires are hard to beat and others like Taylor make fine wires sets too.
To What ignition mods to do?
