Is clearcoating Aluminium a good Idea???
Old Jan 14, 2005 | 08:02 PM
korvette4u's Avatar
korvette4u
Default Is clearcoating Aluminium a good Idea???
if so, what products are available ??? ppg?
for intake,/ plentium/ other aluminium parts not subject too high heat?
Old Jan 14, 2005 | 08:06 PM
comp's Avatar
comp
i'm going to try the Eastwood stuff
Old Jan 14, 2005 | 08:48 PM
JCAIRE2's Avatar
JCAIRE2
In the machine shop we used Krylon off the shelf rattle can clear on cast aluminum. Will take 5 or six good coats to get into all the little cast dimples.
Old Jan 14, 2005 | 08:54 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Krylon is all I used on my intake, plenum and runners and it's still looking good after 3 years.
Old Jan 14, 2005 | 09:03 PM
korvette4u's Avatar
korvette4u
did it darken the Aluminium?...although kyrlon...has it place...i wanted somethin in ppg paints....
thnks
Old Jan 14, 2005 | 09:26 PM
jackslt4's Avatar
jackslt4
Yes, indeed - the Eastwood high gloss clear powdercoat works beautifully on intake manifolds, valve covers, etc. It does not darken the aluminum at all and will last for years. As to clearcoat, there is no reason that should not work either. Intakes and valve covers are low temp applications. But I would expect either powdercoat or clearcoat to burn off of any hi temp surface like heads in the areas near the exhaust manifolds. Powdercoating blocks also works quite well.
Old Jan 14, 2005 | 09:31 PM
bowersock's Avatar
bowersock
St. Jude Donor '05
Default colors
Just had my plenum and runners powdecoated.
Old Jan 14, 2005 | 09:58 PM
korvette4u's Avatar
korvette4u
the question is: what ClearCoat product can be used to PAINT ALUMINIUM????? OTHER THEN Krylon
I Wish not to powder coat
anyone with a product discription??????
Old Jan 15, 2005 | 03:57 AM
korvette4u's Avatar
korvette4u
Old Jan 15, 2005 | 08:08 AM
jackslt4's Avatar
jackslt4
Use any clearcoat - Martin Senour, DuPont, etc. They're all the same stuff. Make sure the part is clean and then follow directions. But be careful. These products contain isocyanates and can do some serious damage to you. Wear a respirator, paint suit, rubber gloves.
Old Jan 15, 2005 | 11:09 AM
korvette4u's Avatar
korvette4u
Thats i thought..clear it is. >OMNI-SV , (PPG second line of paints, 4-1)<..realize the parts need to be clean , ther are sand blasted now will use grease/ wax remover just before spray..please let me know if this is suitable...
thanks
Old Jan 15, 2005 | 11:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
The best product like that I've used is POR-15-They have a couple of clears, one that yellows (careful). I haven't checked with them in awhile, but they used to make one called glisten, I believe-Looks a mile deep! Their product dries rock hard and looks great!
Old Jan 15, 2005 | 05:32 PM
korvette4u's Avatar
korvette4u
RITE ON that the kinda answer i was looking for....i gonna start painting with the "OMINI-SV" 2 part Clear"...it has its own harder and does dry clear...about three coats...i will posts pics later tonite...
BTW: Thank you!!
Old Jan 15, 2005 | 07:04 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Any reason why not?
Old Jan 15, 2005 | 07:14 PM
Bilyk's Avatar
Bilyk
has anyone tried duplicolor clean engine enamel?
Old Jan 15, 2005 | 07:22 PM
korvette4u's Avatar
korvette4u
yes i tried it years ago.. it a good product...but i just been watching some tv...kinda like the idea to color match to body color...sooo the engine will be painted on tuesday, meanwhile i finished the pan , timing , valve covers and just finished clearcoating the intakes (silver, red, metal flake)..in answer to "why not power coat"...is "I DONT WANT TO " ... that should be clear enough!
BTW: thanks , PS: pic later tonite
Old Jan 15, 2005 | 07:38 PM
redbullapril23's Avatar
redbullapril23
POWDER COAT THEM!!!!!!
it will last longer and resist the weather and high temps.
I can coat them!!!!
I have freaking awesome deals! I also do ceramic coating and eep cryogenic processing
please email me or pm me
Slimshaby@mindspring.com
To Is clearcoating Aluminium a good Idea???
Old Jan 15, 2005 | 08:34 PM
korvette4u's Avatar
korvette4u
I can coat them!!!!
this is priceless...
...I am thinking...... .......uhm uhm....... .......... "NO".....and thats my final answer!
Old Jan 15, 2005 | 08:39 PM
Jeffvette's Avatar
Jeffvette
Whatever, no need to be a drama queen
Old Jan 15, 2005 | 09:46 PM
smacko's Avatar
smacko
What about alloy clearcoated wheels?
