After reading through the last 25 pages of this section and not finding anything about my issue with my '91 TPI (the very last probably), I dare ask for some massive help!
I've been driving my Corvette for 5 years now and for the first time I am encountering a problem that I can't solve and which isn't described in the service manual.
Symptom: I get a readout from the tachometer of around 1800 rpm at cold idle, 1400 rpm when warm. Knowing the sound it makes at 2000 rpm quite well, at that sound the tachometer indicates about 4000 rpm. And that isn't all... During a kickdown, the rpm's go way beyond the red mark on the meter. The same goes for the oilpressure gauge.
Now the rpm's are limited on the Corvette, so the readout must be false. Now the question: what's wrong and how do I fix it?
P.
L98's do NOT have a RPM limiter in the ECM. Technically there is a fuel shut off RPM, but it's set rediculously high in the stock chip, like 10K RPM, and the lack of upper RPM flow in the TPI is usually a limiter in and of itself. That being said, I think there could be a problem in the filter described above, might try bypassing it. Or somewhere else in the ecm or the dispaly itself. I'm not familiar with this problem so I can't be of further help.
The computer system in the 90-96 C4 is a little different... well, compared to then it is, but common now.
It uses a CCM - Central Control Module - to handle all communications between the ECM and the EBCM (ABS and then later, the ASR). The CCM is the source of all data on the IP.
This is why the first diag that needs to be done is to plug in the scan tool and read it's data. Compare it to the IP data.
According to the service manual, the CCM controls all responses of the IP except for some analog gauges. My LED display is fine and so are all the light-indicators, so I don't think the IP died completely. Oil pressure also seems to be about 20% off (too high) by the way.
For the CCM, this also controls the lighting of the IP corrected by ambient light with which I sometimes have problems, I had a SYS error about one year ago that disappeared soon enough, which could very well be a bad ground. If the tach filter uses the same ground as the CCM this could explain something...
A bad ground could very well be the problem, since I had almost all of them, except for some of the hard to reach ones. It solved about 90% of all trouble I had after I bought her. How do I get to the tach-filter ground?
If it is the bolt I think is mentioned (under/behind engine block, driver's side), I fixed it already. Could it also be one of the two I didn't fix already: the IP grounds? Any easy way to get to these grounds of the IP without demolishing 80% of my interior?
I think both grounds for the IP and CCM are on the inner kickpanels.
The tach filter is a little black cylinder thingy just off the distributor.
Hey I have the same problem with my 91.....If you fix it let me know what it was...I also believe its a ground somewhere but have yet to find it,.So PLEASE if you figure it out let me know....THANKS Al
Thanks a lot guys, I'll try to fix those points as soon as it stops raining again here... In my country it stops raining at least 3 times per year...usually at night. I'll report back asap!!
I was told to replace the instrument cluster and it should fix it ... but judging by the cost I havne't done it yet... Mine is a 1990 with the same problem... I'll be watching this thread also...
Here's another question... In the 1990 and 1991 , is the odometer reading held in the instrument cluster or the computer or somewhere else... Just curious....
The CCM is connected to the two grounds left and right behind the kickpanels. I just had those kickpannels off than it started raining AGAIN! I think where you guys live is where God works, where I live is where he pees...
G109, a ground below the engine block is one I did before, which grounds the oil level check for the CCM. So the false indicator I get must be because of bad grounds in G201 and G202 (the IP grounds also for the CCM). But this doesn't fix the tach-problem.
The only thing left is G108, which is the ground for the tach filter. If this doesn't work, the tach filter is gone and I'll replace it. As usual with a lot of Corvette parts, I probably need a guy with 1.5 inch thick flexible arms and the power to see through metal to do this. Anyone live near Area 51 that could send me one?
I have a 91 and my tach is off ~200~300 rpm.
(I scan mime frequently so I know it doesn't agree with the scan data.)
Not bad as yours but it still bugeths me.
If the tach filter fixes your I may change mine.
RE The Tach Filter
Is that justa capacitor to ground similar to the condensor in a point distributor system?
If so anybody know the capacitance value?
I am not sure if it's all that simple... the filter takes out the square wave so the tach can display the RPMs more accurately. Without it, the tach would be jumping like crazy.
