Clutch Hydraulic problem
) and it's still not working. I took the slave off and bench blead it...didn't work. Opened the bleader valve and blead it the old fashioned way...still nothing. I can get it blead but when I put it all back together and step on the clutch there is very little pressure. After bleading everything if I pump the slave cylinder from the bottom it will bubble at the top. I've tried everything but this still bubbles when I'm done and won't move enough to disengage the clutch. The reason for this clutch blead is about 3 weeks ago I went to put the car in gear and it wouldn't go so I opened the resovouir and it was empty so now I'm fairly confidant that I have a parts failure...but which part? The slave or the master??? If anyone can think of something I'm missing before I throw money at this I'm open for suggestions. Otherwise, which part is more prone to fail or which one would you start with?
I know GM has had a big problem with slaves... more than masters.
I would start with trying a Pheonix tool. It will pump fluid up from the bottom. This way you know the system is bled.
If I had to guess? slave is done. It will blow it's seals internally, blowing pressure into the outside chamber... but if the outer seal is good, you will never see it.
I would replace the slave cylinder first (NAPA should have one that is cheaper than the GM unit), but you mentioned that the master reservoir was emptied at one point. That fluid had to go somewhere. Do you see any areas being wet with fluid? Is the hose dry?
Hoses will go bad and expand internally under pressure or even spring a leak. The hose is no longer available from GM and according to Scorp, the replacement hose in Ecklers doesn't really fit right without bending. Any good hydraulic hose shop can make another one using the original metal fittings.
Another possibility (but fairly remote) is a worn-out or broken stud that the throwout arm sits on or even a throwout bearing.
Three years and 30000 miles ago I had both master and slave replaced, hoping to be done with the problem. I'm sure it's the slave this time as that's where the puddle is forming.
So the real question is, do I try the GM part again or do I buy the part elsewhere? Would it make any difference in trying to get a replacement part that is not from the bad batch?
One important thing here, after I fill my reservoir and pump the pedal a few times the clutch acts normally. Until it gets low again. In your case, since you can't get any hydraulic pressure after filling the problem might be in the master cylinder.
Also someone asked if I had seen any puddles, No I haven't. Since the fluid does have to go somewhere that has me a little worried in case it drained into the clutch housing, but I don't know if that would be a major problem.
If you cant find any wet spots than you don’t have a leak.
As for bleeding the clutch system. It’s even simpler than the brakes.
I’ve never bench bleed anything and have always got it right the first time.
Assemble the system and fill the reservoir with fluid. Leave the slave detached from the bell housing, hold the slave in such a manner that the hydraulic hose is at the highest point.
Actuate the slave plunger with your thumb. The first few strokes will just pull in fluid to fill the empty void of the slave.
Now here’s the key. When you depress the plunger and the air bubbles rise up into the reservoir hold the slave plunger in the depressed state for at least 30 seconds.
This allows the air bubbles to rise and escape from the reservoir.
If you just depress the plunger and then let it go without waiting it will pull the air bubbles right back into the slave.
I can do this job sitting next to the front tire reaching under the car, and still be able to look into the clutch master reservoir to see the bubbles.
Once you get the master changed, fill it up and with the car on level ground slowly depress the clutch pedal and you will see bubbles rising from the line. Do this until you have a firm pedal and no bubbles.
The hardest part about this job will be contorting yourself to disconnect the retainer clip on the clutch pedal. The rest is very straight forward.
ZZZASY
'96 LT4
