Clearing error codes: True or False
Old Jan 15, 2005 | 10:06 PM
MikeC4's Avatar
MikeC4
Default Clearing error codes: True or False
I want to clear my error codes on my stock '95 LT1. Will the following procedure work?
"To clear the codes from memory, remove the negative battery cable for a minimum of 10 seconds. Very Important: Make absolutely certain the ignition key is turned to the off position. You run the very real risk of destroying the ECM/PCM module if you connect the battery with the ignition switch turned on.
Disconnecting the battery will clear all stored codes but it will also clear the radio button presets, clock, trip odometer, average gas mileage memory, power seat memory (if you have that option) and anything else that stores something in memory. Your ECM/PCM computer will also have to relearn your driving habits again and adjust the timing/mixture/exhaust emissions to your driving style."
Old Jan 15, 2005 | 10:08 PM
bogus's Avatar
bogus
Yup. Pretty much sums it up.
Old Jan 15, 2005 | 10:10 PM
MikeC4's Avatar
MikeC4
thanks bogus....you da' man!!!!
Old Jan 15, 2005 | 11:20 PM
smacko's Avatar
smacko
True AND false - ECM usually retains memory unless ASDL pins are jumped.
Old Jan 16, 2005 | 12:50 AM
VenkmanP's Avatar
VenkmanP
Dude. This is like the fourth tech post by you I've run across in the last few minutes that was either just plain wrong or just plain unhelpful.
Service manual says disconnect power for 30 sec. That's it.
Old Jan 16, 2005 | 01:49 AM
bogus's Avatar
bogus
since when?
Old Jan 16, 2005 | 01:57 AM
tempest's Avatar
tempest
Mike, you should also be able to do it by removing the ECM fuse for 30 sec too.
Old Jan 16, 2005 | 02:00 AM
bogus's Avatar
bogus
Old Jan 16, 2005 | 02:20 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
The book says take out the ECM fuse for at least 10 seconds
Old Jan 16, 2005 | 03:01 PM
Brimis's Avatar
Brimis
Sounds right. I just cleared the codes this morning after replacing the timing chain. Codes 22 and 42. I disconnected the power for 10 seconds, reconnected and drove the car for about 20 minutes.
Old Jan 16, 2005 | 05:36 PM
MikeC4's Avatar
MikeC4
Thank you gentlemen! Since I still have not gotten a munual for my C4, could you please tell me where the ECM fuse is located? This sounds easier than disconnecting the neg. battery terminal, especially 'cuz previous owner stripped it, and I need to use vice-grips....DOH!
Old Jan 16, 2005 | 05:52 PM
Jloshotz's Avatar
Jloshotz
I believe the fuse should be labelled ECM or ECMB possibly both. Should be in the main fuse panel; anyone confirm?
Old Jan 16, 2005 | 05:57 PM
NightFlight's Avatar
NightFlight
On my '87 it is on the main.
Old Jan 16, 2005 | 11:05 PM
tempest's Avatar
tempest
on the main also for my 92.
Old Jan 16, 2005 | 11:34 PM
bogus's Avatar
bogus
ECM is the engine controller, EBCM is the brake (ABS) computer.
Old Jan 17, 2005 | 12:18 AM
cash's Avatar
cash
8th Gear
Default ecm
Disconnect the battery, it is the easy way. You will loose your radio presets.
You did not want them anymore, right?
Key off it's the safest way, why would you leave it on anyway?
Recomend that till you get a book and be sure of what you want to do.
This is the sure way to make you car forget his "problems".
Old Jan 24, 2005 | 12:16 AM
MikeC4's Avatar
MikeC4
Hey guys,
Does this make sense:
1)codes thrown:
H-22
H-44
H-64
2)Then removed neg. bat cable for at least 30seconds or so:
3)Then reconnected neg. bat cable
4)Did not start engine
5)Checked to make sure codes cleared, but still got this:
H-64
(Right oxygen sensor voltage was below 0.2 volts for 50 seconds of closed loop operation.)
Shouldn't this code have cleared? Closed operation is with engine fully warmed up, and I didn't even fire it up?
Thanks in advance!!
Old Jan 24, 2005 | 12:54 AM
VenkmanP's Avatar
VenkmanP
H-64 (Right oxygen sensor voltage was below 0.2 volts for 50 seconds of closed loop operation.)
In my manual, there is no "of closed loop operation" in the title.
It says that this error can occur with the engine off, because the voltage should still be around 0.450 if the engine is off.
It does imply that the key would need to be on for 50 sec before the code would be set, so I'd expect it to be cleared right after the battery disconnect.
Old Jan 24, 2005 | 08:24 AM
runner140*'s Avatar
runner140*
Default You got it......
That procedure works on my 1996. I used that procedure to clear the SES code several times.
To Clearing error codes: True or False
