Easy way to remove OEM mufflers?
Old Jan 16, 2005 | 05:33 PM
proemtpff's Avatar
proemtpff
Default Easy way to remove OEM mufflers?
Is there a easy way to remove the OEM mufflers off of my '86 coupe? I've been under the car for a hour now beating the crap out of those things trying to get them loose. Help please! I have new mufflers arriving tomorrow.
Old Jan 16, 2005 | 05:36 PM
vader86's Avatar
vader86
No, not really.
Spray them down with WD40 and let it sit awhile, then go try again.
Old Jan 16, 2005 | 05:38 PM
gbody5's Avatar
gbody5
Sawsall if you have one. Cold chisel a slot from the neck end to where the clamp was to allow it to slip off.
Old Jan 16, 2005 | 05:39 PM
gbody5's Avatar
gbody5
Previous was assuming you have the clamps off, if not, then yes soak with penetrating oil.
Old Jan 16, 2005 | 05:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Sounds like you need to slot the pipes with a sawasall or Dremel; some PB Blaster might help too if the pipes won't move at all.
If you mangle the Y-pipe ends you may need a tapered plug to drive in to open them up again to fit the new mufflers.
proemtpff's Avatar
proemtpff
ALL the clamps are off. I've had it soaking, tried heating with a propane torch "that helped some, it helped it rotate a inch or so". There is a nice crease where the clamp was......is that whats holding me up?
Old Jan 16, 2005 | 05:48 PM
NightFlight's Avatar
NightFlight
If you're able to rotate the mufflers but not slide them off, the crease is probably your problem. As the other's have said, try cutting a opposing slots (one on each side) of the neck on the mufflers to split them open a little bit -- should slide right off. A RotoZip, Drummel or Sawsall should get the job done.
Old Jan 16, 2005 | 05:51 PM
ClarenceT's Avatar
ClarenceT
Just be careful not to cut too deep
Old Jan 16, 2005 | 08:16 PM
1stC3Vette's Avatar
1stC3Vette
I used a hand held 10,000rpm grinder and cutting wheel. I had it from some previous body work I was doing on a '65 Mustang. You can rent these or buy them. They cost about $60.00 and the discs are about $5 or $7 a piece. You just have to be careful to cut through only the outer pipe. Makes easy work of the clamps.
Good luck.
Dino
Old Jan 16, 2005 | 08:19 PM
froggy47's Avatar
froggy47
Did you get the pipe RED hot?
Old Jan 16, 2005 | 08:25 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Before you get too involved with removing the mufflers, double check the first bend of your Y-pipe. Tap it with a screwdriver and check for wall thickness. After carefully removing th OEM muffs on my 86, the Y-pipe was rotted through. Lots of work for nothing....
Old Jan 16, 2005 | 08:51 PM
REW89's Avatar
REW89
Unless you are certain your y pipe is new or in excellent shape I have found it saves a lot of time just to replace y-pipe at the time I changed mufflers. That way the job is almost a simple bolt on job and you are sure both components are top notch condition.
MTCW Bob
Old Jan 16, 2005 | 11:13 PM
skybolt31's Avatar
skybolt31
I am about to replace from the Cat back on my 86 tomorrow, should I be getting new hangars or are they usually reusable?
Old Jan 16, 2005 | 11:21 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Some systems come with new hangers....
What are you installing?
Old Jan 17, 2005 | 08:43 AM
skybolt31's Avatar
skybolt31
It is a Dynomax system, I bought it used from another forum member, no hangers. He said it was too quiet for him, so I am hoping it is just right for me!
Old Jan 17, 2005 | 08:57 AM
Brimis's Avatar
Brimis
What generally happens is the clamp is so tight that it makes an indentation around the Y pipe making it almost impossible to remove the mufflers.
I would get a sawzall with a new blade and cut the mufflers. Don't struggle with an old blade, you can have them off in 5 minutes.
Old Jan 17, 2005 | 09:47 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Barring that, take it to a muffler shop.
Larry
code5coupe
To Easy way to remove OEM mufflers?
Old Jan 17, 2005 | 08:37 PM
MrRenoman's Avatar
MrRenoman
It's been awhile since I removed mine. I think I just cut through both pipes right on the crimp. I removed whatever piece was left on the Y pipe and slipped my new ones on and clamped them further up the Y pipe with no problems. I sold my old mufflers and the guy who bought them never said a word. I only cut off a couple of inches, I think, maybe less. Was a lot less work than trying to heat, and bang and slip them off.
Art
Old Jan 17, 2005 | 08:49 PM
proemtpff's Avatar
proemtpff
Used my air "ZIP" saw, made two relief cuts on each pipe. A few wiggles and off they came. THANKS FOR ALL THE HELP!!!
Old Jan 17, 2005 | 10:22 PM
snoopdan's Avatar
snoopdan
I was gonna suggest going to your local walmart at 3 in the morning and driving over the speedbumps at 70 mph. Works for Fiats !
snoopdan
