Pully elimination question...
Since this forum has helped me so much with my Vette problems, I'd like some info on a related winter project I'm starting. I'm Installing an '88 L98 into a hotrod and I would like to clean-up the outward appearance of it as much as possible. I would like to remove the AIR pump and plumbing and put a small K&N type air filter on the T.B.
I would like to retain a serpentine belt system, mainly for appearance but don't really want to add eliminator pullies if I don't have to.
The engine will remain totally stock, so I was wondering if I could do this and how it would effect a computer-controlled engine. Where also can I find a belt to fit the new arrangement?
Thanks. I hope this is not too Unvette-specific to be on this forum.
To do it you would have to convert to the later computer and use a MAP sensor.
first, the belt is routed to that all components turn the right way. rerouting the belt will not accomplish this.
second should you remove the air pump, the belt comes around the altenator is too steep of an angle to clear other cmnponents creating interferance..i have researched to it's end and found no way of fitting/rerouting the dam belt when removing the air pump...
so this is why the air pump eliminator was born.
once the air pump is gone and the ARP is installed, the emissions system can be removed. starting with the air valve/switches/attached hoses etc. egr under the plentum, egr sensor under the distubutor and plugged with block off plates
, any vaccum lines attached to them and plugged. you may also remove the pipes that are attached to the headers or plug them.there will no codes if a lower thermostat is used. ther is a fix for this as well,, ask 65z01 for details , he help me with that.
hope this will help
Start here for routing ideas: http://www.marchperf.com/gallery_chevysmall.html
