Hurst Shifter Install Help!
Old Jan 19, 2005 | 08:15 AM
96 CE LT-4's Avatar
96 CE LT-4
Default Hurst Shifter Install Help!
I have all the new parts installed onto the hurst shifter from doing the work on the bench and i am proceeding to put the shifter in the car, but i am having a problem getting the pin back on from underneath the car that locks the shifter to the transmission. Any creative tips that you had to use. I can get it started about an 1/8 of an inch on the shaft but as soon as i try push it on a little more the shifter pushes the transmission shaft into the motor like its changing gears and does not allow me to access the hole so that i can punch the pin back in. Any help is greatly appreciated, i spent 2 hours last night wrestling with this part and it won.
Old Jan 19, 2005 | 08:35 AM
LD85's Avatar
LD85
If I rememeber correctly,
I stuck a Phillips screwdriver in the holes to align the pin holes, then shifted the shifter top end forward so that the linkage was pulled backwards,
then I grabbed the shaft that goes into the tranny with a pair of needle nose and held it from moving, then pulled the phillips and put the pin in.
Old Jan 19, 2005 | 09:11 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
This gave me several problems as well. Just because of this step I will never do another shifter install on these cars again. LD85 explains the best 'one man procedure'. I needed someone to hold the shifter stick in place while I messed around under the car. I ended up getting my neighbor to help me. He held the stick while I worked the pin in place. I also ended up heating the dowel pin with a torch to make it easier to work with, and bashed it in with a hammer.
Old Jan 19, 2005 | 09:39 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
With a little grease, I was able to get the dowel pin to stick in place at the top of the shifting linkage. Then with the pin stuck in the top hole I mated the linkage to the tranny shaft and pushed down very gently until the pin slid into place. I had to be careful it wouldn't fall out of the bottom. Then I slid the ring in place. Make sure the ring is firmly around both ends of the pin. Good luck with the boot after this. It is also not easy.
Old Jan 19, 2005 | 09:45 AM
96 CE LT-4's Avatar
96 CE LT-4
Oh man this has to be the most PITA mod ever, but hopefully it will be worth it. Some great suggestions so far. I have been trying to do this with the pin already installed in a little bit, but maybe i should try pulling that out and then reinstalling after everything is aligned. Great advice also on the needle nose to keep the trans shaft from pushing back in.
Old Jan 19, 2005 | 10:43 AM
1989redvette's Avatar
1989redvette
when i did mine 2 weeks ago i took the pin and groung a small chamfer around the one end then drove the pin in the collar slipped the assembly in and slid the collar onto the shaft after it was on i taped the pin lightly so as it would drag a bit then tapped it forward till i felt it free up thus indicating it was over the hole.. since it is now chamfered it will drive right in took less than 5 minutes.. i also made sure the retaining ring clip was all ready expanded on the collar as well so all i had to do is slide into the groove once the pin was installed
Old Jan 19, 2005 | 11:28 AM
Glasman66's Avatar
Glasman66
I used needle nosed pliers to align the holes and pounded the pin in.
Some go easy some are a nightmare.
Old Jan 19, 2005 | 11:53 AM
TM-Z06's Avatar
TM-Z06
You think that pin is a PITA, wait til you have to put the lower boot back in place.
Old Jan 19, 2005 | 12:53 PM
96 CE LT-4's Avatar
96 CE LT-4
Oh man, i was hoping that boot wasnt going to be too bad to put on, but looks like another headache going forward. UGHHHHH
Old Jan 19, 2005 | 01:18 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
It will be worth it when you shift it.
Old Jan 19, 2005 | 03:50 PM
LD85's Avatar
LD85
I tapped my pin from the bottom with a regular flat punch, I did not have to hit it hard.
If you shift the linkage backward you should have lots of clearance
The Boot was a B!@T$H to put on though!
Old Jan 19, 2005 | 08:44 PM
ZF Six's Avatar
ZF Six
I spent like 1.5 hours on my back in the driveway working on that freakin' pin. I had someone hold the shifter in place while I punched it in. HUGE PAIN but definately worth it and I'd do it again if I got another C4.
Old Jan 19, 2005 | 10:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Glad I did mine with the transmission out during a clutch change.
It took just 1/2 hour.
Old Jan 24, 2005 | 01:03 PM
96 CE LT-4's Avatar
96 CE LT-4
Thanks for all your help guys! The shifter is in and feels great. Now if only this snow will melt so i can take her out for a test drive.
To Hurst Shifter Install Help!
