code 15 & 26 - help please
Old Jan 20, 2005 | 12:43 PM
reed62783's Avatar
reed62783
Default code 15 & 26 - help please
1992 a4
i am having codes thrown- at first i thought it was b/c my exaust leak, but i decided to check anyway. It gave me code 15 and 26.
Code #15: Coolant Temperature Sensor Circuit Low.
- what is that
Code #26: Quad-Driver Module #1 Circuit.
- and this means-lol
any input is very appreciated
Old Jan 20, 2005 | 12:56 PM
reed62783's Avatar
reed62783
is it possible that the code 26 was caused b/c i removed my cats? i read that it has to do the airpump and some relays that is used to heat the cats on startup?
Old Jan 20, 2005 | 02:27 PM
bogus's Avatar
bogus
yes, #26 could be caused by removal, but usually only removal of the system...
15? That is simple, get a coolant temp sensor. either that, or it has come off the waterpump.
Old Jan 20, 2005 | 03:31 PM
reed62783's Avatar
reed62783
ok fixed the 15- the sensor had a broke plug connector.
i am calling compcams to see if they think the removal of my cat caused a code. if so they can reburn it for me.
Old Jan 20, 2005 | 04:05 PM
bogus's Avatar
bogus
As I said, I don't think it's the removal of the cat, it's would have to be an electrical problem with the system. I would not be surprised if you neglected to attach a connector...
To code 15 & 26 - help please
