Rear Lear Spring
Old Jan 20, 2005 | 05:06 PM
chucks88's Avatar
chucks88
Default Rear Lear Spring
I have the tension off of my rear spring in the above pic. Should that spring have more tension(such that it would look closer an upside U) or is it about where it should be.
The reason I ask is .........In Jesse's D36 to D44 swap tech tip he mentions it looking like an upside down U when the tension is relieved.
Chuck
Old Jan 20, 2005 | 05:35 PM
froggy47's Avatar
froggy47
That's about what mine looked like off the car, should not be more "U" than that.
Check for splits, cracks in the composite. Tiny ones ok.
Old Jan 20, 2005 | 07:27 PM
vstol's Avatar
vstol
The arch will depend on the spring. On my stock 96 the spring had a considerable arch and after switching to a VBP spring it now has very little arch and the ride height is where it needs to be. I agree with first checking the spring for signs of wear but with it attached and the car on the stands how does the car sit and maybe more importanly how are the axles in relationship to the ground?
Old Jan 20, 2005 | 09:12 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Looks just fine. Clean with mild soap and water, then check for cracks or dents. Both are bad.
-JRC-
Old Jan 20, 2005 | 10:10 PM
chucks88's Avatar
chucks88
Okay..........great. I didn't notice any cracks/splits ETC. but I'll take another look. Thanks for the responses.
Chuck
To Rear Lear Spring
