1/4 mile times
Old Jan 20, 2005 | 11:01 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
man I'm slow
Old Jan 20, 2005 | 11:25 PM
scofolo's Avatar
scofolo
my time and mods are in my sig
Old Jan 20, 2005 | 11:56 PM
NitrousSam's Avatar
NitrousSam
Not in my Vette but in my street driven 1982 S-10 with street tires and mufflers.
9.41 at 143 with a 1.27 60 foot on Hoosier quick time pro street tires.
5.98 at 114 in the 1/8 miles. (same run)
Engine made 800 horsepower at the flywheel with a mild nitrous tune up. The et and horsepower lead me to believe there is more in my combination that I haven't found yet.
Old Jan 21, 2005 | 12:55 AM
Kwik88's Avatar
Kwik88
See sig. Started tearing it down last night looking for more!!
Old Jan 21, 2005 | 08:12 AM
85vet's Avatar
85vet
Cruise-In V Veteran
See sig.
Winter tweak in process!!!!!
Old Jan 21, 2005 | 10:25 AM
85blkrose's Avatar
85blkrose
best
14.10@95.50 mph
1.88 60' w/2.73 rear
vortex ram air,bbk 52mm throttlebody,afpr 43psi.,accel bluethunder coil,high output module,msd wires,stock plugs .045, hypertech thermo chip,160* stat, descreened maf,2.5" borla cat back.and some other free mods.
Old Jan 21, 2005 | 11:33 AM
88421VETTE's Avatar
88421VETTE
Originally Posted by CFI-EFI
I didn't make myself clear, AGAIN! My times are corrected ONLY for the physical altitude. NOT for the atmospheric conditions. The density altitude does not change the actual, geologic, physical, altitude of the track. The NHRA ET correction factor for RMR's 4400' altitude is .9458. That doesn't change if the temp is +110 degrees, or -110 degrees.
14.7 x .9458 = 13.903. The mph correction number is 1.0573. So a 93 mph 1/4 mile speed corrects to 98.33. Better weather and a lower DA may make your car faster, but these are the times corrected to NHRA sea level equivalents.
Not bad, actually. Especially if it's a Crossfire. When I first went to the track, the best *I* could muster was a 16.75 @ 4400" feet, with about a 2.40, 60'. I think I've done fairly well for a mostly stock Crossfire and little money. Keep at it.
RACE ON!!!
thanks now I know how to correct my time somewhat thanx. cause it is pitiful posting 1/4 time from these high altitude
when I started racing I started at a 15.3 at 91mph
Old Jan 21, 2005 | 11:57 AM
mike 1985's Avatar
mike 1985
Default best
3130 lbs carbed 1985 corvette
motor 12.63@109..1.77 60'
100 shot 11.38@ 118..1.55 60'
150 shot 10.98 @ 124...1.65 60' ( I dynoed 380 RWHP and 600TQ) Don't know what smokemup.com says
next year car and driver will be 3000 lbs with 51% on the rear and i'm dual staging a 250 shot ( trying for 10.50 @ 130)
355 9.8-1 ( orig motor)
Canfield heads out of the box
comp nitrous cam 218-230 @ .050 113 LSA 460 lift
RPM intake ( vic jr this yr)
750 VS elec choke carb
hooker super comps, 2.5" duals and dynomax muffs
turbo 350 10" midwest converter, modified stock shifter
stock D-36 3.07 gears
MT 26X11.5 X16 ET street.
My friends completly stock motor LT-1 firebird ( 3300 lbs) stock manifolds, air box, Y pipe, AC, nothing removed from orig motor.
motor 14.0
150 shot 11.52 @ 116...1.55 60' homemade low pressure dry kit
200 shot 11.003..1.50 60' @ 120 200 HP homemade propane kit
turbo 350 10" converter
stock rear 373 gears
28X9 MT Slick.
10.70 is his goal
Old Jan 21, 2005 | 02:34 PM
jp2002ls1's Avatar
jp2002ls1
Carbed 350 in a 1985 vette.
Only time at track with new motor it ran a 12.61 @112 mph but it was bogging bad off the start.
Old Jan 21, 2005 | 02:38 PM
mike 1985's Avatar
mike 1985
did you get it figured out ?
Old Jan 21, 2005 | 03:07 PM
CFI-EFI's Avatar
CFI-EFI
That's a lot better than when *I* started. 16.75
RACE ON!!!
Old Jan 21, 2005 | 04:29 PM
88421VETTE's Avatar
88421VETTE
RACE ON!!!
Yeah but look how much you've improved damn good job. and if anyone ever thinks you've done more to you car than you say you. I'll tell em what I seen a friggin Crossfire that out runs my modded tpi
Old Jan 21, 2005 | 05:07 PM
  #33
CFI-EFI's Avatar
CFI-EFI
I've been pleased with what I've been able to accomplish. And for next to nothing, too. Have you seen under my hood?
RACE ON!!!
Old Jan 24, 2005 | 01:14 PM
  #34
88421VETTE's Avatar
88421VETTE
RACE ON!!!
yeah you popped it at Rmr 2 years ago
Old Jan 24, 2005 | 02:25 PM
  #35
jburnett's Avatar
jburnett
9.91 at 141.4, 1.48 short, ZF6, Street Twin, 250 hp shot on a 571 hp (n/a at the crank) 396 SBC. That was at 3455 with me in it and 1/3 tank of gas. This is the '90... It will be DEEEP in the 8's with the new combo...
9.15 at 148.7, 1.21 short off the back tires, G101 4 speed, Ray Franks multi-disk clutch, 4-link rear, 440" BBC, legal NHRA Super Stock 'C' 1966 Vette
11.71 at 119.6, 1.68 short on 3.73 geared D36. 383 SR/A4 combo in wifey's 1985 Vette. 372hp/441tq at tires.
-Jeb
Old Mar 8, 2005 | 12:50 AM
  #36
korvetkeith's Avatar
korvetkeith
Hey Jeb, you might be able to take to the 6 speed and IRS record from the Heffner Viper. That would be wild. Good luck.
Old Mar 8, 2005 | 01:07 AM
  #37
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
See Sig
To 1/4 mile times
Old Mar 8, 2005 | 01:38 AM
  #38
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If using the DataMaster 1/4 time estimator counts, my very stock 86 ran a 14.02 @ 98.5 Only engine mods are going catless with Borlas.
Old Mar 8, 2005 | 03:26 AM
  #39
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
11.75 118.5mph 1.71 60' time 400rwhp automatic, 428ft/lbs tq.
Old Mar 8, 2005 | 08:18 AM
  #40
LT4BUD's Avatar
LT4BUD
So what is everyone posting...real or corrected times......
I need to go look at my timeslips.....I thought they were actual but ?????
