MISSING>>>><<<<?
Old Jan 21, 2005 | 08:59 PM
ar91c4's Avatar
ar91c4
Default MISSING>>>><<<<?
OK well this car its getting on my nerves...LOL...
Anyway its a 91 and it seems to have a dead miss.I replaced wires,cap,rotor,coil,fuel filter,,also did a fuel pressure check and turned it from 50 down to 44lbs....timmed it back to 6* ...And ran my scanner on it and everything seems fine.If I put the car in drive and sit still idling, every 45 seconds to a minute it misses hard.I can also feel it when driving down the road if I ease on the gas.
I was thinking a bent valve but if that was the case it would constintley miss..tomarrow I am going to go to the shop and do a leak down test,....
Anyway if anyone has any idea on anything else it could be please post it.thanks guys...hopefully I will figure it out tomarrow
Old Jan 21, 2005 | 09:07 PM
mikey whipreck's Avatar
mikey whipreck
i didnt see spark plugs on your list... and if so are they gapped appropriately?
Old Jan 22, 2005 | 12:33 AM
ar91c4's Avatar
ar91c4
I have replaced all the plugs too........even though its missing its still faster than a 03 lightening!!!!!!!!!!!!!!My buddy has a black one and we raced 65 to 130 and i gained at least 2 cars on him...not to bad for a 91 compared to a 03, but then again it was a ford....
Old Jan 22, 2005 | 12:37 AM
bogus's Avatar
bogus
ok, whats the gap?
And street racing kills are not permitted on the forum... with all the deaths resulting from street racing, and the nature of modern society, if the forum permits bragging, means that we support it, and someone could sue the forum for such support, if they do it and someone gets killed.
Old Jan 22, 2005 | 12:40 AM
ar91c4's Avatar
ar91c4
ok...I will remember that in the future...and I set the gap at 35....which I believe is stock....thanks
Old Jan 22, 2005 | 02:59 PM
ar91c4's Avatar
ar91c4
ok i did a compression check and all read 125lbs but #6....it came back 160lbs???????I think I have a bad injector on that cylinder and its filling the rings with gas there for giving me the high reading..the plug looks good and has no sighn of oil present.although it does smell of gas pretty bad....does anybody else have any other ideas before I take my plenum off and change the injector????thanks guys.
Old Jan 22, 2005 | 04:38 PM
C4Crazy787's Avatar
C4Crazy787
Make sure you check all the plugs for cracked insulators, same thing happen to me and thats what it turned out to be. Good Luck.
Old Jan 22, 2005 | 05:23 PM
bogus's Avatar
bogus
125 psi sounds LOW to me....
Old Jan 22, 2005 | 05:52 PM
ar91c4's Avatar
ar91c4
LOW???????Aldata on my work computer shows stock should be lowest 100psi. and within 20% of eachother....so why does 125 sound low?
Old Jan 22, 2005 | 06:53 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
#6 @ 160 does not sound right? Possible valve/cam problem????????
Old Jan 22, 2005 | 07:09 PM
ar91c4's Avatar
ar91c4
I shouldn't gain compression on #6 if I had a cam/valve/spring problem..I think if that was the case I would have low compression on that cylinder.I know its not oil and the only other thing that I can think of that would cause high compression would be gas in the cylinder causing the rings to seal.(open injector).........anybody every experianced something like this from a factory engine?
Old Jan 23, 2005 | 10:21 AM
Chris_G's Avatar
Chris_G
I'm sorry that no one else has responded and I don't have an answer for you.
If you're sure it's the injector. You could disconnect it (wiring harness)@ cylinder #6 and recheck compression in that cylinder. If the compression goes to the normal range like the rest, you were right
My thoughts on the valve\cam issue was maybe they were staying closed too long. Thus, building compression.
I hope someone will chime in here with better insight to help you out.
To MISSING>>>><<<<?
