Need some definitions, BHP,CHP, RWHP
CHP Crank Horsepower
Crank horsepower is probably a term that people have just made up to estimate engine horsepower based off of rear wheel numbers. BHP is what is actually measured on an engine dyno.
Crank horsepower is WHERE that measurement is being taken from, as is RWHP.
Crank horsepower is sometimes called CrankShaft HorsePower (CSHP) or even FWHP or FlyWheel HorsePower.
It can get rather confusing, sometimes.
Larry
code5coupe
Manufacturers would run the engines out of the cars with nothing to hold them back. They experimented with engine temperature and ambient temperature to obtain maximum HP.
Larry
code5coupe
Yes "horsepower" is WHAT is measured......
but,
"brake" is one type of HOW it is measured...this is usually obained directly on an "engine dyno" using a electric dynometer....which could simply be described as an electric motor trying to run in the opposite direction as the internal combustion motor...by measuring the electric power it takes to maintain constant speed you can determine the motor horsepower
"gross" refers to measuring the engines horsepower (on an engine dyno) when all of its own needs are furnished externally.....water circulation, fan cooling, alternator, no air cleaner, no exhaust.....every trick in the book to to get a big horsepower number
"net" refers to measuring the engines horsepower (on an engine dyno) with all the normal power using accessories attached to the engine..
"crank" refers to WHERE the horsepower is we are talking about....usually data obtained from an engine dyno..."gross" or "net"...often now we estimate what would be at the crank based on data obtained at the rear wheels...
"rear wheel" refers to horsepower at the rear wheels and is obtained using a chassis dynometer.......horsepower is calculated based on the acceleration rate of the large drum that the wheels drive..
"rear wheel" is a more true measure of "net" horsepower because now you have subtracted the drive train losses along with the losses associated with engine things, like alternator....
"corrected" usually refers to adjusting horsepower measurements to "standard" atmospheric conditions
Now what I don't know.....how is horsepower obtain on an "inertia" dynomoter related to "brake" horsepower..........example: changng to a lightweight flywheel would not change brake hp since friction would not change....but the extra inertia of weight would effect the "inertia" dyno reading..
I've never heard of a dynamometer that used that particular method, but I suppose it's possible. Would take a HECK of a big electric motor to equal 400-500hp......
Larry
code5coupe
Larry
code5coupe[/QUOTE]
Used in some local motor factories......
Several kinds tho..
http://www.taylordyno.com/eng/maineng.html
http://www.mustangdyne.com/
Actually in some industrial worlds a 500hp motor isn't all that big.....10,000hp is big!!!
Larry
code5coupe
-Joe
