11 second C4?
Old Feb 8, 2005 | 02:52 PM
mike 1985's Avatar
mike 1985
What is the cheapest and most reliable means of accomplishing this with a 300hp late model C4?[/QUOTE]
you guys must have missed this part of his post. Heads , cam, intake, will run you easily $3000 plus, probably more.
Old Feb 8, 2005 | 10:01 PM
jimbomill's Avatar
jimbomill
Originally Posted by MrNuke
Thanks Jay, finally found this thread. I am knocking on 11's with the new tranny/TC so hopefully this season I'll have it.
My mods are :
-Slightly (ahem) ported superram intake (Upper/lower)
-Slightly (double ahem) ported old dart iron eagles (200cc runners,64cc polished chambers, modified exhaust ports, bowl blended, 2.00/1.60 manley swirl valves and 'light-duty' springs for my stock cam's paltry 430 lift.
-LPE 1 5/8" Longtube Headers
-Custom 3" exhaust / High-Flow Cat to 2 1/2" Targa Mufflers
-Dana44 with 3.45 rear gears.
-Nitto 555R Drag Radials
-2400RPM stall converter and new 'performance' tranny w/cooler
-52mm AS&M ThrottleBody
-Air-Pump eliminator Pulley
-Modified SLP-Ram Air system
-Powercoupler
-Slightly leaky 24lbs injectors (LT1 style MULTEC's)
-Modified AFPR
-A/C bypass belt
-Spark PLug cutback Electrodes
-I burn my own chips and tune the car myself.
Sounds like a lot, but it's all pretty simple stuff. The engine has 117K miles on it, and is running strong as an oxe (with that said prolly will blowup next week now).
Total expenses = Around 3K, and that's including $2400 for the tranny .
(Yes, I am a cheap bastards who waits for good deals
How much were the LPE 1-5/8" LT headers and the custom exhaust? Do all your mods after the tranny only total 600 (you said total expenses were 3K including 2400 for the tranny) bucks? If so, I need you to teach me how to shop!
