i want both but the packages i was looking at by Fidanza(sp?) only are the stage II lightweight flywheel kit can i get that and just purchase a single mass from someone else? is there a place that sells both as a set? please help me shed some light on this. i am getting more and more confused
check out carolina clutch - first check out their website then give them a call and ask for Tom, tell him you're from the forum and they'll take care of you.
You might want to check with McLeod as well. I am not sure how much their aluminum flywheel goes fo seperately, but I've read good things about it. I think it is 12.5 lbs. I will be putting one on as soon as the UPS guy gets it to me!
didnt one of these companies have a test on a ZO6 where they put on a lightweight flywheel single mass conversion and it gained X amount HP? anyone know what im talking about or have the article?
Here are calculations on the benefits of the light flywheel in virtual weight reduction in replacing the 39# dual mass with the 13.5# Fidanza. Note that it is a function of gear ratio--
Gear 1 2 3 4 5 6
Mass Reductions lbs 303 203 116 80 56 39
