A couple of questions to the guys running these.I am looking to install one of these,the car will mostly be a daily driver,will I need to install a seperate cooler?If so where does it go?
Yes. Where ever it fits. Mine is in front of the A/C condenser.
Slipping converters cause heat, Heat is the number 1 killer of automatic transmissions. Higher stall converters cause more slippage and heat than a stock converter. In my mind, the answer is, yes, it's "a must do". As soon as I hit the "submit" button, someone will post that they have been driving around for years with a 5000 rpm stall converter and no cooler, with no problems. Listen to what others have to say and make up your own mind. You know MY feelings.
Isn't that the truth!
As for a tranny cooler being a requirement, it's not a hard and fast rule to do so, but I did it just to make sure I didn't kill my tranny.
I run a Vigilante 2600 and was told by Precision a cooler was not necessary.
However, I'll join the club by saying its cheap insurance and you should get one. I used the B&M Supercooler and mounted it in front of the a/c condensor.
I would tend to agree with getting another cooler. I mounted mine on front of condensor. Tranny will have a better chance of a longer life if you put one on especially with the extra heat from bigger converter.
I have the same converter. I had the trans shop that built my trans install the converter at the same time. I didn't ask Precision or the trans shop if it was needed. I just said, Do It!
With all the C4 automatic failures we read about, on here, every day, I can't imagine anyone taking the gambol.
It's your money. You can pay now, or you can pay later.
I have this same converter, 2800 stall.. Works great.. I too say to add the cooler, althought I don't have mine in yet. Buy one of the "plate" type, they have much more cooling area per square inch than the tube type..
Chris
is it possible to run the aftermarket cooler along with the built into the radiator. also what is the easiest way to install an after market cooler the cooler I have has some hose a hose and a couple fittings in it but the hoses aren't long enough to reach the front of the radiator?
