Higher max rpm
Old Jan 24, 2005 | 01:54 PM
vette95's Avatar
vette95
Default Higher max rpm
Can I raise the rev limiter on a LT1 engine with roller rockers to the same as the LT4?
Old Jan 24, 2005 | 02:08 PM
Z06_BluByU's Avatar
Z06_BluByU
my instincts tell me no...
Mainly because the LT4 has lighter valves and stronger springs.. I think if you changed the valve springs out you would be able to spin it higher..
Old Jan 24, 2005 | 02:46 PM
Nathan Plemons's Avatar
Nathan Plemons
If you're running LT4 springs I wouldn't raise it very far for the reasons mentioned above. If you're running overkill on the springs you can easily turn the stock bottom end to 6500 RPM's.
Old Jan 24, 2005 | 03:08 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Why? you planning on going 180?
Old Jan 24, 2005 | 07:06 PM
FELNGR8's Avatar
FELNGR8
Well, you can raise the limit of an LT4 to 7000 and the engine will live. I wouldn't try that on an LT1 stock bottom end.
I raised the limiter on my LT1 to 6400 and even with the Hot Cam kit the power is falling off there. No need to go higher than that.
Old Jan 25, 2005 | 01:07 AM
Mo_Bandy's Avatar
Mo_Bandy
6250 here, I'm running stock springs, HD springs are next upgrade...
I agree, even supercharged the peak power starts to fall off at about 6100 or so ....
mo
Old Jan 25, 2005 | 02:10 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Don't we all? I am.
Old Jan 25, 2005 | 02:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by Rich & Lisa_84
Don't we all? I am.
How's that systemax coming along?
cv67's Avatar
cv67
St. Jude Donor '05
Don't we all? I am.
Old Jan 25, 2005 | 04:25 AM
vette95's Avatar
vette95
It´s because it shouldn´t hit the rev limiter when shifting 1-2. I don´t know if it will,haven´t driving it yet with the new gears,just wondering if the engine can take it.
Old Jan 25, 2005 | 11:48 AM
FELNGR8's Avatar
FELNGR8
My dyno tuner told me to raise the limiter and then shift below it. He doesn't like what happens with the fuel starvation limiter method.
He won't take an engine near the limit on a dyno pull.
Old Jan 25, 2005 | 11:28 PM
Rich & Lisa_84
This thing is freaking awesome. I'm going to swap the 750 Q-Jet for a 770 Holley Avenger and then come the Long tubes. It won't be long until the rearend and tranny explode. It is not a tire roaster from take off. But if you floor it at anything over 10 mph it will give you a headache when your head hits the seat. It idles very rough and is a little shy on vacuum when in gear at a light, but still streetable.
I am having a slight traction problem when the 4 barrel kicks in and I have wornout a rear set of tires in 3,000 miles (Don't tell Lisa).
I am also in hopes of rebuilding the bottom end so that I can turn higher RPM's, I am shooting for 7,000 RPM reliability.
I will get it on a dyno this Spring and post the results.
Thanks for asking.
Old Jan 25, 2005 | 11:32 PM
comp's Avatar
comp
shooting for 7000 RPM reliability
Old Jan 26, 2005 | 06:26 PM
LT4BUD's Avatar
LT4BUD
Not to dispute this as many people have done this with great success,
BUT
When GM made the LT4 they made improvements in the "bottom end" over the LT1 in order to raise the rev limit to 6300....improved crank, piston rings, ....
An LT4 is more than an LT1 with a head job....top end work
http://www.grandsportregistry.com/lt1vslt4.htm#CRANK
To Higher max rpm
