engine bogging
Old Jan 24, 2005 | 09:47 PM
BLK/BLK'93's Avatar
BLK/BLK'93
Default engine bogging
We have a 93 LT1 A4. Just recently the car is bogging down when the petal is pressed over 3/4 to the floor. It is just about the same place as the kick down. When you press the gas till the trans down shifts, the trans will downshift, but then if I keep the petal down the car just keepds bogging. If we press the gas all the way down it boggs continuously, and reduces power and speed. If I then slowly back the petal off, it will begin to regain power when it is back past the 3/4 to the floor. The only time it boggs is when it is past 3/4 to the floor, and it does not stop bogging until I back off the gas. The car is stock with no mods. I am thinking fuel pump or fuel filter. No codes. Even in park, if I push the petal over 3/4 way to the floor, bogging.
Old Jan 24, 2005 | 10:17 PM
MikeC4's Avatar
MikeC4
I am thinking the same as you.
restrictive fuel filter, faulty regulator, faulty fuel pump.
Did you check it out in park. Does it "bogg" at certain RPM?
Put on a fuel pressure gauge, turn on engine, manually turn the throttle, see if FP drops.....just my $0.02
Old Jan 25, 2005 | 07:33 PM
BLK/BLK'93's Avatar
BLK/BLK'93
Changed fuel filter, and problem solved. I can not beleive how much more power the car has now. It is like I have a new engine. Hard to beleive a $10 part could cause a car to run so bad.
Old Jan 25, 2005 | 07:46 PM
85 500 horse's Avatar
85 500 horse
Glad to hear your problem is solved. If only everyone's problems could be so easily and quickly solved as yours, life would be so less stressful.
Old Jan 25, 2005 | 07:52 PM
MikeC4's Avatar
MikeC4
Alright!! You cured the "bogging" syndrome!
To engine bogging
