L98 Valve Cover Gaskets?
Old Jan 25, 2005 | 01:39 PM
geezel's Avatar
geezel
Default L98 Valve Cover Gaskets?
I'm looking for "thick" valve cover gaskets for my 86 with center bolt valve covers due to rocker clearances. I've been using Mr. Gasket #5868 (3/16" thick molded rubber) but they don't produce these any more. Where else should I look?
Old Jan 25, 2005 | 01:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try the PermaDry from FelPro, they work well with my ProMagnum RRs.
But I had to reduce the drip tabs and narrow the bolt towers a little.
Old Jan 25, 2005 | 02:26 PM
mikey whipreck's Avatar
mikey whipreck
i know i've seen these recently... but I can't remember where at. Have you check summitracing.com?
Old Jan 25, 2005 | 02:38 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
I got some Fel-Pros recently in stock at O'Reilly's.
Old Jan 25, 2005 | 03:06 PM
geezel's Avatar
geezel
OK - Thanks.
To L98 Valve Cover Gaskets?
