Finally ran my 427 LS7 swapped vette at the dyno and drag strip
Old May 10, 2026 | 11:05 PM
bjankuski's Avatar
bjankuski
Default Finally ran my 427 LS7 swapped vette at the dyno and drag strip
It has been a long time coming but I was finally able to get my 1986 vette swap with the 427 completed over the winter. For those who do not know the car has not run since 2014 and this winter I got it mostly completed. The basics of my combination are listed below:
-1986 vette
-Full street interior and car is at full weight of 3473 LBS as raced on friday night with the driver
-427 LS7 with a stock bottom end but has a LS7X texas speed cam 248/256 @ .050 with .624/612 lift
-Melrose headers
-2000 camaro computer running the engine and 4L60E transmission with 4500 stall and lockup
-3" dual exhaust system
-Ford 9 inch rear conversion with 3.73 gears
-275 drag radials
-4" maf sensor
-Engine makes around 650 to 700 horsepower
-Full cage certified to 8.5 ET's tucked nicly in the car so you can not really even see it unless you look
I have a tune mostly dialed in, there may be some additional power hiding in there but not a lot
The car looks like a sleeper, looks like any stock C4 corvette and at the strip you can barly hear it run compared to most of the cars there.
I dynoed the car on a Mustang dyno in the unlocked condition with a conserative tune (Rich and pretty conserative timing and the car made 510 RWHP at around 6900 RPM but it was still climbing and I lifted to make sure I kept all the parts inside the engine. Dyno sheets attached.
It was in this condition that I ran the car on Friday night and the car ran well, the DA was 1700 ft at it went a 10.22 ET at 131 MPH. (I was hoping for a 9 but I can live with what I have)
Car was very conststant I ran 5 times at it ran between 10.22 to as slow as 10.25. It also pulls a nice 6" wheely at the launch.
I also data logged the car with HP tuners on the runs and pulled data on the 0 to 60 times, and 60 to 130 times which I have never done before at the strip. 0 to 60 ET was 2.35 seconds approximately, and 60 to 130 was 7.8 seconds approximately
Run attached:
File Type: pdf
Old May 10, 2026 | 11:10 PM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
This is the kinda stuff I love. You could surprise so many people.
Great times! Congratulations and thanks for sharing.
Old May 11, 2026 | 09:12 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
That’s very impressive. Nicely done!
Old May 11, 2026 | 11:46 AM
XLR8-R's Avatar
XLR8-R
That is awesome! That does not look like a 10 second car. Congratulations on the results of your hard work! I wish the drag strip close to me had not closed down.
Old May 11, 2026 | 11:53 AM
fredk's Avatar
fredk
Wow great results and great work !!!
Old May 11, 2026 | 02:06 PM
383vett's Avatar
383vett
Nice work! Congratulations. 9's with some tuning.
Old May 11, 2026 | 03:21 PM
bjankuski's Avatar
bjankuski
I hope so.
Old May 11, 2026 | 04:38 PM
STEVEN13's Avatar
STEVEN13
Awesome! Nice looking car!
Old May 11, 2026 | 10:52 PM
bjankuski's Avatar
bjankuski
Default Engine pictures
Old May 12, 2026 | 07:22 PM
tpi 421 vette's Avatar
tpi 421 vette
Nice work. That's making some power
Old May 13, 2026 | 02:30 PM
Krusty84's Avatar
Krusty84
Wicked cool.
This makes me want to swap to an auto. Those 60ft times are awesome and consistent.
You are making excellent power and running excellent times for a first outing in what I assume is a near full weight car.
I bet there is more in the tune as well. On an inertia dyno, I would bet it is closer to 600whp than 500.
I also bet your 60 to 130 times are mid to low 7s on a Dragy. I guess it is possible they could be slower with the auto, my calculations using HP tuners log were always faster than the Dragy. My 6.0 5 spd stripper '84 runs low 8s in ~2000DA and a best of 7.93 in -800DA on a the Dragy. Best runs were 11.60 at 126 with 2.0 60ft.
Old May 14, 2026 | 07:19 PM
96 lt-4's Avatar
96 lt-4
Kudos to you sir! Excellent first outing. I bet you couldn't wipe the smile off of your face! I love it with the saw blade wheels as well. Stock sleeper. Grudge night money maker! Now get that nitrous kit hooked up!!
Old May 15, 2026 | 05:27 PM
bjankuski's Avatar
bjankuski
thanks
Old May 15, 2026 | 08:31 PM
arthursc2's Avatar
arthursc2
What AC relocation kit did you use?
Old May 18, 2026 | 07:28 AM
bjankuski's Avatar
bjankuski
To Finally ran my 427 LS7 swapped vette at the dyno and drag strip
