C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Stalling Problem
Old May 5, 2005 | 08:52 PM
Bell Curve's Avatar
Bell Curve
Default Stalling Problem
I just got my 1990 ZR-1 and it has been running ok, but I am getting all the fluids changed and get a tune-up with filter, plugs, etc.
A few days ago it stalled out on me, and it felt and sounded like it was not getting fuel. I was almost home when it stalled out but managed to get it home with a few more starts and stalls. I cranked it up later that night and it ran fine. Then today, I started it and she was doing fine, but after five minutes or so it stalled again like it was running out of gas. Any ideas as to what is going on? It will start over and over, but it keeps stalling out. If I let it sit for a while it does fine, but after a short while it stalls out. What is your guys best guess as to what is going wrong?
TIA
Old May 5, 2005 | 09:20 PM
bad-zr1's Avatar
bad-zr1
Both fuel pumps are on when the car is started and at 176 degrees water temp one is turned off. See if you are losing fuel pressure about then. I think it is the secondary that is turned off. Your primary could be going bad or leaking.
Old May 5, 2005 | 11:51 PM
Bell Curve's Avatar
Bell Curve
Is that the only thing it could be, because that sounds expensive.
No chance it is a filter, or some other problem?
If it is the fuel pump, anyone know how much it is, and how much of a pain it is to change it out?
Old May 6, 2005 | 12:05 AM
Cdn Z06 Mike's Avatar
Cdn Z06 Mike
If it is, the fuel pumps are inexpensive. Use the fuel pumps from a 1996 GMC Suburban with the 454 engine as they are identical to the ZR1 and will cost roughly$100 or so for both pumps.
Old May 6, 2005 | 12:22 AM
webgear's Avatar
webgear
I would start by having the filter changed.
Old May 6, 2005 | 08:41 AM
Bell Curve's Avatar
Bell Curve
I was hoping for more opinions as to whether or not everyone thinks it is a fuel pump problem, or could it be something else I could check?
Assuming it is the fuel pump/pumps, could it be clogged with varnish or debris? If so, is there a simple fix like a fuel additive to clear it or something? I am assuming the fuel pumps are in the tank so hopefully there is a cheaper fix?
Ok thanks for the reply, but if they are identical, why wouldn't I just order a GM fuel pump for the 90 ZR-1? Also, are there any aftermarket pumps for our cars?
TIA
Old May 6, 2005 | 08:47 AM
DDSLT5's Avatar
DDSLT5
TIA
Fuel pumps are easy to replace - I did it in 30 min. Pull the assembly from the tank, cut the zip ties and remove the hoses, old pump out, new pumps in.
You could buy the ZR-1 specific item - it is the whole assembly as the manual says it is a non-serviceable item - costs over $1000.00. Get you hands dirty and save $800.00.
Old May 6, 2005 | 09:24 AM
8388's Avatar
8388
St. Jude Donor '14
Another possibility could be the relay.
Old May 6, 2005 | 10:34 AM
Z Factor's Avatar
Z Factor
While it sounds like a fuel pump, you should start simple, then progress. A $ 0.05 fuse could be the problem, so open up your panel and take a look. I think it will be the fuse at the bottom, farthest to the right.
Keep us posted, and good luck.
Old May 6, 2005 | 11:01 AM
RatRacer's Avatar
RatRacer
The original '90 ZR-1 PROM also had stalling problems. The latest GM PROM fixed that and a couple other issues.
Old May 6, 2005 | 11:43 AM
Bell Curve's Avatar
Bell Curve
I'm all for saving money, and have no problem getting my hands dirty. It is just that I am new to the ZR-1, and do not know much about fixing it yet. I'm hoping with you guys helping me, I'll get it running right soon.
I will check the relay as well. Besides the fuse, how else can you check it?
Also, I think I might have a vacuum leak because when I leave the key on without the motor running, I hear something cycle on every 50 seconds or so. Is that a symptom of a vacuum leak or something else?
As always, TIA
Old May 6, 2005 | 01:06 PM
RatRacer's Avatar
RatRacer
That's the vacuum pump for the secondaries. If it is only cycling once every minute or so, you are in good shape.
Old May 6, 2005 | 02:42 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
As always, TIA
every 50 seconds your fine, you need to worry when it cylces ever few seconds.
as far as the fuel pumps I just had mine out last night takes abut 20 minutes to pull it out and to install
the fuel pump change is easy and the extraction from the tank is easy
if you do it ill walk you through
also check out this webpage for all your ZR1 needs
www.zr1netregistry.com
go to "maintenance"
then click on "ZR-1 how to"
then fuel pump replacement!
even cheaper fuel pumps to use!
http://www.zr1netregistry.com/old_proj11.htm
Old May 6, 2005 | 11:53 PM
Bell Curve's Avatar
Bell Curve
Thanks to you and Rat Racer for the vacuum info.
Also thanks for your offer to walk me through it. I'll check the relay this weekend, and if that is not the problem, I'll buy two of those pumps in the link you posted.
Old May 7, 2005 | 11:34 AM
Bell Curve's Avatar
Bell Curve
Default You Guys Are The Best!
8388 & Z Factor---You guys saved me a bunch of cash.
I went straight to the fuse you described (it was the exact one btw) , and sure enough it was blown. Replaced the little 10amp sucker and my beast is running great without any stalling after it warms up.
As a newbie to the forum and ZR-1 ownership your help is greatly appreciated and invaluable!
Old May 7, 2005 | 12:53 PM
DDSLT5's Avatar
DDSLT5
So the next question you have to ask is: why did it blow?
To Stalling Problem
