Plenum pull issue
I need to go buy some coolant after dinner, then I'll see how it went. I definitely will need new injectors, I could smell fuel from a few of the ports with the ignition on. Seemed like only secondaries, but one primary smelled a little, though it's hard to tell if it wasn't just the secondary next to it (which smelled too). I couldn't see any drips though. I think I'll wait until next year to replace those.
Jeff, you said it's not brain surgery pulling the plenum. It's a good thing I'm not a brain surgeon, then, because I obviously didn't put something back together right.
The car has a high idle, like 1000-1500. But after you punch it, it gets higher to like 2,000-2,200 rpm, which is really annoying. I discovered I didn't hook up one of the middle vacuum lines, but unfortunately putting that back on didn't fix it. The front underneath line is on, the two on the drivers side, and the map one in back, plus the other mid, the brake booster, and the FPR one. So either one of them leaks, there's some other one, the plenum isn't sealed, or I jacked something up when I cleaned the throttle body.
On the plus side, the car was pulling like a freight train! It felt noticeably stronger.
Yea that bolt by the fuel block is a bit of a PIA but I looked at it before the tear down & figured that had to come off to get to that bolt to get it out. I just thought that was evident & I was the only one to not realize the fuel block could be in the way. That's why I didn't mention it. I figured if I did post about, it would be redundant! Sorry! :o
The threads may respond to a tap for clean up & I would think it would be okay. There is not that much T/Q on them.
You can clean the thottle body, etc and look for obvious things like vaccum lines, etc. But it just might be the ECM relearning things.
Check the MAP sensor hose on the back of the plenum, pull it and clean the inside.
I removed that fuel line, removed the single plenum bolt, and put it in straight. It definitely wasn't applying pressure before. It went in straight ok, I cleaned the bolt threads and cleaned up the hole a bit. I think I'll just need to be very careful with it in the future.
That seemed to fix everything, the idle was fine, it drove fine, etc. Then once the car warmed up, I hammered it. Again, wow does it pull like a freight train now! I mean, it pulled hard before , but it's definitely better now!! But right after that pull, the idle was high at about 1,500 rpm. Another slight dig in 5th and it was at 2,000 rpm. I am now thinking it's the PCV cover that needs to be replaced or zip-tied again. It for sure slips off a bit. I don't know if mine is normal, but mine doesn't even sort of snap over the PCV valves, it just slides over easy as pie. You can pull it off with a pinky, there is zero grab to it. So I'm hoping it's just that this is lifting off a little under hard throttle. We'll see... :-\
Edit, oh Joey, the MAP vacuum hose is new, came with the vacuum kit from Kurt White. It's on there ok.
Also when you get your hig hidle, does it eventually idle back down? Can you stab the throttle and release does it idle down?
I have checked to make sure the butterflies are not sticking. They snap back very firmly. Blipping the throttle does nothing to bring the idle down. Once it goes up, it stays up.
ZR1Mack, no codes before or after so far.
So one, what can I do to absolutely confirm it's the lack of dag? Can I put some dielectric grease on the edges to temporarily help it seal? Or something else? Or is that asking for trouble? I just want something short-term where it will fix it, thus giving me confidence that is the problem and not some other unknown bone-head thing I did.
Then second, what can I do to fix it? Can that stuff be re-applied? Can I buy a new TB? Is this a reason to go to 63mm? Thanks!
But it sounds like that is part of your issue. As you are able to get the idle to come down when you let of the gas and the throttle "slams" shut.
I must be getting senile but I don't remember seeing that stuff in my T/B when I cleaned it. Do all T/B's have that stuff? Is it just ZR-1's? Where can I go to read up on this stuff? Sorry Aurora for jumping in like this on your thread.
Tom
