C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
code 42
Old Dec 12, 2005 | 01:25 PM
sKOG's Avatar
sKOG
3rd Gear
Default code 42
I have a code 42 .changed DIS modules and still have it any ideas?
Old Dec 12, 2005 | 01:42 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Check for any bent pins in the connector from R&R.
Why did you change the DIS module in the first place?
Old Dec 12, 2005 | 03:02 PM
sKOG's Avatar
sKOG
3rd Gear
code 42.I ran to town 5 miles and stopped at a store .The check engine light did not come on ,on the return trip .could it have some coolant causing a bad conection.Then it evaporarted with the heat?
Whats the r&r.I'm a newby for these zr1's
Old Dec 12, 2005 | 03:04 PM
Jeffvette's Avatar
Jeffvette
Check the ECM would be the next logical step
R&R is Removal & Reinstall
So this issue was a previos existing issue before you changed the DIS?
Old Dec 12, 2005 | 06:41 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
I just sold Greg this DIS and I was sure it was good to go...
But after installing it he has the same problem??
Im trying to get the pages from the manual to him so he can read the procedure
To code 42
