C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Starter?
Old May 28, 2006 | 06:10 PM
tuband's Avatar
tuband
Cruise-In I Veteran
Default Starter?
Looks like my "no start" condition is the starter
Recommendations, please
1) put a new starter in (TLD in Atlanta has them for $200, no core charge)
2) put a reman in (Autozone has them for @$170, lifetime warranty with a core charge)
3) have the old one rebuilt
I'm leaning toward putting a new one in as well as having the old one rebuilt and storing it as a spare.
Any other ideas? Also, anyone know of any sources less expensive than the ones listed above?
At least I'm getting plenty of practice pulling the plenum .... a couple more times and I'll qualify for "Expert"
George
Old May 28, 2006 | 06:18 PM
tuband's Avatar
tuband
Cruise-In I Veteran
Anyone know about this? ZR1 starter
Old May 28, 2006 | 07:53 PM
mercruiser's Avatar
mercruiser
I think I'd buy a new starter over a rebuilt unit even if it did cost me 30 bucks.Is the new one a delco starter?Rebuilding yours for a spare is a good idea.
Old May 28, 2006 | 09:05 PM
HAWAIIZR-1's Avatar
HAWAIIZR-1
George
George,
I tried to call you and sent you an email that I have a new spare starter for you. $100
Since we are local you can install right away and we can meet up tomorrow or later in the week if you wish.
Craig
Old May 28, 2006 | 09:28 PM
tuband's Avatar
tuband
Cruise-In I Veteran
Originally Posted by HAWAIIZR1
George,
Craig
Check your PM ... I'll be in Augusta tomorrow.
George
Old May 29, 2006 | 12:31 PM
ZR1Rob's Avatar
ZR1Rob
What caused the no-start? Did you was the engine and water got under the plenum? if so, then welcome to the club. I've had that happen twice, once on each of my cars.
Both times, the starter was merely water soaked. Ok, here's what you do. Get to the starter, you are an official member of the PP club, so that is not a big deal. Now, get the starter out and clamp it in a vise. Get some CRC ELECTRIC MOTOR CLEANER. Its got a red extension tube, so use it to really soak the guts of the motor while turning the armature by hand. That will displace the moisture. Now, run some jumper cables to a battery and fire it up, but when the motor runs up, remove a cable from the battery to make sure that it doesnt run very long, a couple of seconds at a time max. Thats it.
Now, if it wont fire up, you can get it rebuilt at a local shop for about $100. It will then be better than new, and warrantied.
PS: while youre under the plenum, open up the drain hole thats supposed to keep it dry under there. Here's how GM outlined the fix: http://www.zr1netregistry.com/bulletins/923076-1.jpg and http://www.zr1netregistry.com/bulletins/923076-2.jpg
I can tell you from personal experience, that once the drain hole problem is fixed, the starter problem is gone.
Old May 30, 2006 | 04:50 PM
tuband's Avatar
tuband
Cruise-In I Veteran
ZR1Rob,
I talked with the previous owner at BG earlier this month and he reminded me that when I bought the Z a couple of years ago that he had some reservations about the starter. I never had a problem until now so I think the no-start was due in large part that I haven't cranked the Z in several months due to modifications that I've been sloooooowly doing. I've discovered that working and modding are not always compatible, time-wise
Anyway, long story short .... Craig (HAWAIIZR1) had a spare starter, we had lunch together yesterday and swapped Army & Corvette stories, and I brought a new starter back home. I'm going to try to get it installed later this evening or tomorrow. Will keep everyone posted of the outcome. Looking forward to waking up the beast after a looong winter!!!
And a big thanks to Craig. The ZR1 community is absolutely great because of guys like you.
George
Old May 30, 2006 | 09:06 PM
HAWAIIZR-1's Avatar
HAWAIIZR-1
ZR1Rob,
George
Hey George,
Thanks again for lunch and always a pleasure to get together with you and look forward to more. You're more than welcome and I'm glad I could help out. It did not make sense for me to sit here looking at the starter when a "Brother of the Beast" is in need. Keith, you like that???
Craig
Old May 30, 2006 | 11:37 PM
kmoudy's Avatar
kmoudy
yes...pampers.. (Craig) .i liked that "Brothers of the Beast"
it really is a true
statement, Huh? i'm buying the viper gears from same place as you..
now our azzes will be cousins??
Old May 31, 2006 | 08:07 AM
Cdn Z06 Mike's Avatar
Cdn Z06 Mike
Originally Posted by kmoudy
...now our azzes will be cousins??
...ummmm ....Craig...you might want to be careful
Old May 31, 2006 | 10:07 PM
HAWAIIZR-1's Avatar
HAWAIIZR-1
Thanks Mike, you're right.....Keith does have a way with words. Gotta love em', he keeps me laughing.
Old Jun 1, 2006 | 12:15 AM
tuband's Avatar
tuband
Cruise-In I Veteran
Starter in
It works
Other problems
Will start new thread ... hope someone can help.
To Starter?
