C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Tuner Control Module
Old 06-05-2006, 10:00 PM
jabrun
jabrun's Avatar
Default Tuner Control Module
Does anybody know where the CDM audio processor is on a ZR-1?
Old 06-05-2006, 11:02 PM
gunnerja
gunnerja's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Right side dash to the left of the fuse box. Enjoy.
Old 06-05-2006, 11:04 PM
phrogs
phrogs's Avatar
depends on the year
Old 06-05-2006, 11:06 PM
gunnerja
gunnerja's Avatar
Correct I know early 90-91 are where I said. Not sure on the later years
Old 06-06-2006, 05:44 AM
jabrun
jabrun's Avatar
It's a '91.
Old 06-06-2006, 07:57 AM
tomtom72
Support Corvetteforum!
tomtom72's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
If the 91's are the same as the 90's it's above the carpet hush panel below the glove box. Factorycarsterorepair.com has a good "how to" on getting the CDM out...the only thing I would add to their instructions is that attached to the bottom of the mount for the CDM is 7 wire bundles w/plugs. If you unplug the bundles & move them over to the left & right, you can work easier...as far as getting the mount & the CDM to separate from each other...oh yea take the stuff off of the front(by the firewall) of the CDM mount...I think they are a bunch of relays and fuse holders...they restrict movement that you need to wiggle the CDM out & back in again. It is tight spaces but if you don't get mad & take your time it goes fairly smooth...I took alot of "attitude adjustment" time outs!:o
Tom
Old 06-06-2006, 10:55 PM
jabrun
jabrun's Avatar
Thanks for all the help. I was staring at it the whole time but I saw what I thought was clear vaccum tubing going into the module so I thought it was a climate control processor. It turned out they were wires with clear insulation covering them.
To Tuner Control Module
Quick Reply: Tuner Control Module
