C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
injector testing without pulling the plenum
Old Sep 4, 2006 | 05:09 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Default injector testing without pulling the plenum
I jumped on hiebecks website but im a bit confused on the procedure or i need some longer leads on my equipment!
I need to check these babies out becuase I really think that the injectors are my problem, the fuel system is im perfect shape drove it with the guage coming of the rail straight to the windshield so I could watch it as I drove and at idle its at 40# when I hit the gas he jumps to 50-55# so Im geting fuel to the rail.
but then the stumble and jerking and stalling happens with plenty of fuel on the guage!
Old Sep 4, 2006 | 05:45 PM
matszr1's Avatar
matszr1
It's not a pefect test but you can check the ohms on each injector pretty easy. You can get to the electrical plugs on the injectors without too much hassle. Remove the plug and test between the two leads on the injector itself. I don't recall the resistance they should be but you can tell if there is one or two that are way off. This will at least tell you if you have one breaking down. It doesn't tell you how good your flow is though.
Old Sep 4, 2006 | 05:47 PM
xlr8nflorida's Avatar
xlr8nflorida
Old Sep 4, 2006 | 06:09 PM
Aurora40's Avatar
Aurora40
Here's a thread that might help:
http://forums.corvetteforum.com/show...jector+harness
Old Sep 4, 2006 | 07:18 PM
phrogs's Avatar
phrogs
ok im going out to try it, I figured you could do it at the ecm but I was looking through my electric supliment instead of big red ill check it and get to it.
thanks
jp
Old Sep 4, 2006 | 09:46 PM
phrogs's Avatar
phrogs
ok they all check good except for # 7 primary @ 6.5 and # 3 primary @ 6.8
and this is just the selonoid test who knows what flow and spray patterns they have
To injector testing without pulling the plenum
