Engine discolored
also, which #s on my vin is my production? The are 3 zeros toward the end of the vin followed by a 88 which is the last 2 digits. Does this mean my car is #88?
You can't really bring back the luster of the engine - what you can do is have it repainted the original color, or better yet, have it powdercoated a similar color for a stunning shine. You can also consider painting it the colors of your choice too.
Enjoy!
From what I've seen over the years here, no one has really found any cleaning method that doesn't make it worse. Or that doesn't cause it to worsen over time.
First and foremost, remember : NEVER pressure wash (or ANY wash) this motor. Water will collect in the valley and cause you much headache.
Pulling the cam covers and plenum isn't too hard. I'd say it's worth every penny to send them out for powder coating.
Enjoy!
the latter part of his observation is correct
although...since he and i both own..1990 Zr1's he had a bit of a
brainfart...when he quoted the top paragraph..since your car is
a 1991..it probably didn't get the little extra massage..
dwight was speaking of...
you see, they wanted the first zr1's to be perfect.
the first 60 or so..went to GM executives..and friends...
my car is number...#74... and a 1990..but it still doesn't absolutley
guarantee extra anything...although..i'd like to think...hiding somewhere in the
car..is a gold nugget or diamond or ect...
check the inside of your drivers door it has the build date.
One of our members here, JEFFVETTE does the powder coating on
these engines...and his work is A+++ LocoBob his partner will also
do a little porting for you..at the same time..to add a few ponies.
check em out...
good luck with your zr1 hope to meet you in Bowling Green in may.
It looks shinier in the picture than in real life.
I cleaned mine when I took the top end off, I just used a nylon brush and a mild degreaser. If you use something like Simple Green, I'd probably dilute it like 8:1 as it can be caustic.
