C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Replacing u-joints
Old Mar 8, 2007 | 02:08 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Replacing u-joints
Doing some work this afternoon and came across this little mess. Had a ABS/ASR issue with loss of signal from the right rear sensor. I pulled the sensor out to clean it and noticed the gear teeth sheared off.
Old Mar 8, 2007 | 03:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
So whats the story behind the carnage?
Old Mar 8, 2007 | 11:33 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Are you sure its U joint could also be bearing
Old Mar 8, 2007 | 12:15 PM
Jeffvette's Avatar
Jeffvette
U-joints were part of the work. Car has almost 100K and some of them are clicking. While the suspension is a part bushings are being done as well.
Old Mar 8, 2007 | 12:17 PM
Jeffvette's Avatar
Jeffvette
Ron, I have not done a failure analysis on it yet. I need to bolt everything back together on the bench and look it over. One possibility is that some garbage got up in the speed sensor gear and tore everything up.
To Replacing u-joints
