C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Random Tech CATs #
Old Oct 3, 2007 | 02:12 PM
DMark's Avatar
DMark
Default Random Tech CATs #
Anybody have the part numbers for the RT CATs that can be bolted up to a set of SW Headers?
Thanks,
Old Oct 3, 2007 | 05:14 PM
1990 QUASAR BLUE's Avatar
1990 QUASAR BLUE
The ones that I ordered are the 3" in and 3" out slip fit bullets. Part # is 14130000. Martell Bros used to have the best price but are now no more. http://www.ultrarev.com/storefront-c0.html now has the best price that I know of.
Old Oct 3, 2007 | 05:28 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Random Tech Metallic core pn 703000 can be orederd direct. Ph# 770-554-4242. Expensive at @ 239.00 each.
Cheaper @ 59.00 each:
http://www.performance-curve.com/ind...OD&ProdID=1181
I "believe" the 141's are ceramic core.
Old Oct 3, 2007 | 06:41 PM
DMark's Avatar
DMark
Originally Posted by FU
Cheaper @ 59.00 each...... I "believe" the 141's are ceramic core.
Hot Dang! The link said that they are Metallic brick!
Has anybody used these?
Old Oct 3, 2007 | 07:33 PM
1990 QUASAR BLUE
I thought the same thing but it seems that 703000 is the old part number. 141-30000 is the new number for the same cat.
http://www.ultrarev.com/product.php?productid=42595 206.00 each.
BTW, 59.00 for a hi-flow cat! If they flow the same and are of similar quality that's one helluva deal.
Old Oct 3, 2007 | 07:34 PM
FU's Avatar
FU
The C5 and F-Body guys use them often. For the price and being that they are metallic substrate I can't see how they would be a bad choice.
Detailed Description
Thunderbolt cat's are designed to give high performance in limited spaces. This high flow converter features a Metallic brick with 300 holes per square inch. This 100% EPA legal OBDII catalytic converter is designed for engine's up to 5.9L / 6000 lbs. (Not for use in California)
Part # - 415300
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
Brick Type - Metallic
Material - 409 Stainless Steel
Old Oct 3, 2007 | 07:35 PM
FU's Avatar
FU
Old Oct 3, 2007 | 08:35 PM
WVZR-1's Avatar
WVZR-1
Default The "409"!
The primary drawback to the #415300's advertised specs is the "409 stainless". It's not much better at managing condensation than just plain carbon steel. It is the least expensive stainless out there. Random doesn't display the stainless grade that I can see but it would be worth the asking before a buy.
In a weld on environment I believe I'd want the something better than maybe the "409"! Condensation likely leads to the "ruination" of the Borla systems everyone mentions.
Old Oct 5, 2007 | 02:58 PM
DMark's Avatar
DMark
Originally Posted by WVZR1
The primary drawback to the #415300's advertised specs is the "409 stainless"......
I think most OEM stainless exhaust system's are 409.
Old Oct 5, 2007 | 04:15 PM
Rkreigh's Avatar
Rkreigh
need to see the CFM flow data. sounds cheap, for sure the random cats are expensive, but they flow over 600 cfm and definitely work.
I'd like to try these other ones on "removable" cats as they sure would save some coin. the advantage of the randoms is that from my standpoint they are proven.
Old Oct 5, 2007 | 05:12 PM
HAWAIIZR-1's Avatar
HAWAIIZR-1
I want to install my SSW headers too and in the market for some CATs. Is this a get what you pay for and I should only consider the Random Techs; it sure would be nice to save some $ where possible? I don't need CATs here in Hawaii, but it is the responsible thing to do for our environment and I imagine I want to keep the noise down with my B & Bs. Well, if I can afford the Raptor TTs, then I guess it my B & Bs would just gather dust and cobwebs.
To Random Tech CATs #
