Winter Project
Winter Project
With todays weather, was wondering what everyone has on tap for this winter. For Me:
1)Port Plenum/IH/Port match IH to heads
2)Clean up the under carriage/engine/inside of wheels
3)Short Shifter Install
4)Replace plug wires
5)Test Ign modules
Does anyone know a good way to store injectors while I have them off the plenum, seem to remember that they can get messed up if let exposed, I still have the caps from the replacements.
LGAFF
92 ZR1
#234
5)Test Ign modules
LGAFF
92 ZR1
#234
I'm just going to do some car cleaning/restoration type stuff. Mostly, I'm just going to refresh the interior.
I'm going to do the new OEM stereo, new stereo capacitors (my stereo sucks)
New shifter handle
New window tint (former owner scratched the hell out of the current tint)
Just that stuff because I really don't know much about motors... Otherwise, I'd probably try to add some HP
New shifter handle
If you want to get greedy - do a plug check and see what ones are running fatter/leaner and do a poor mans flow match with the injectors pulled from the offending cylinders.
MAP vs. MAF?
5)Test Ign modules
LGAFF
92 ZR1
#234
5)Test Ign modules
LGAFF
92 ZR1
#234
1) What hp/torque gain are you expecting from doing the plenum port (and polish?) project?
2) My understanding of the (90) Zs is they do not employ the MAF, but rather MAP/computation to regulate fuel mix. So, unlike the (direct MAF method) does not altering the air flow (increasing it) also suggest a chip change to accommodate the increase?
I'm definately on the steep side of the learning curve w/ the LT5s. But, it is a lot of fun, just the same!!
P.
PS- I noticed you are from Crystal Lake. I live in Custer Park, about 25 miles south of Joliet - We're practically neighbors!
I am going to ge this exhaust situation rectumfied and then replace the oil pressure sensor and oil level sensor and install a new steering wheel and send the radio to dr don to get the CD player rebuilt and replace the switch on the drivers bolster motor...other than that, I have to save some money to fix the problems that seem to always creep up on any ZR-1 I have ever had every few months. Otherwise I would be sending the parts off to be powdercoated.
Engine oil works well on the injector o-rings also, and might be less questionable as to the effect? Though if those things can withstand fuel, they can probably withstand vaseline.
I will be changing my oil pan gasket, as it's slightly drippy. And hopefully I'll be installing coil-overs over the winter (or having them installed if it's over my head).
I also kinda want to dyno my car as-is, and then with an x-pipe in place of the resonator to see what kinds of gains there are to be had. Even though I like how the exhaust sounds, and it's a little on the droning side, I can't help but still want to mess with it.
Location: No more yankee my wankee, the Donger is tired!
1 Post
Lot's to do on the 91:
Low compression 368
Full polished SS Turbo System
Alki Inj
Powder Coat the engine
New Shelby Wheels and Mich Pilots
Swap the hand fabricated Turbo System to the 90
Sell the A-Molds & GY-D3's
Deep Clean and polish the suspension
Roll Bar & Fire Extinguisher
Outer rubber window seals
Low compression 368
Alki Inj
Here is my list:
Be cool radiator
Install DRM wilwood brake kit front/rear
New front knuckles, wheels studs
DRM MC
lower front and rear
Bushings
refinish wheels
new tires
CAGS eliminator
X pipe
Valvecover gaskets
Exhaust check/tighten up
Engine clean up + CF parts
car polish
Interior plastic parts refinish (only a few samll parts)
Be cool radiator
DRM MC
Bushings
refinish wheels
new tires
CAGS eliminator
X pipe
Valvecover gaskets
car polish
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
I'm in the camp of "Drive her till the snow flies!"
Ofcourse I'll fix anything that comes up.....so I can keep drivin'. I already did most of my winter fluids changes because I got a charity run comming up with the NYMC & the F-chat guys...wouldn't miss that run for anything as they're a fun bunch.
Oh yea my winter list...I forgot the intent of this thread....heater core, DREM, stero head again, send out shocks for rebuild, fix water leaks....yea all the fun stuff....someday I hope to get to do the go fast stuff.
WINTER..
Since its going to be sitting in the garage anyway, I plan on
Cleaning up the under carriage, changing the trans fluid and I am thinking about swapping out my BB resonator for an X pipe, and I need new brakes so I am looking into a brake upgrade.
