Runner Porting - How is it done?
Can somebody explain exactly how the plenum runner porting is done? Since we're dealing with a bent tube (I'm guessing) 5 or 6 inches long, how do yo get in there and remove the right amount of material and not get the walls too thin? I assume there is some sort of a flexible bit or reamer available?
Hans
Hans
Received 3,043 Likes
St. Jude Donor '05
THe divider doesnt run all the way up as far as I can tell. Takes a lot of time to learn actually. Just making stuff bigger, or "hoggin stuff out" can in some cases lose you performance and in the process ruin a perfectly good part. I know nothing about the latter
