C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Header Install
Old Jan 22, 2008 | 03:43 PM
HammerZR1's Avatar
HammerZR1
Default Header Install
I am installing headers and am going to replace the stock bolts with SS hex head (allen) cap screws/bolts. Anyone know the size of the new bolts I will need?
Old Jan 22, 2008 | 05:07 PM
95ZR1's Avatar
95ZR1
IMHO, with cap screws and limited access you will not be
able to tighten some of the screws. Tube bends get in the way.
Some you can't get at straight on and since you can't see
them anyway, why make it harder on yourself?
Hex bolts allow socket access straight on or wrench access
from the side. I bought new (shorter)bolts from Fastenal- I can look
them up if you want.
Maybe your headers allow fit/use of a 90 degree hex wrench.
Still, the fun part is removing the heat shielding.
If you must:
http://www.zr1products.com/images/He...lation_Kit.jpg
I did not need oxygen sensor extentions or dip stick tube mods and assembled all the stuff myself.
Old Jan 22, 2008 | 06:37 PM
HammerZR1's Avatar
HammerZR1
Originally Posted by 95ZR1
IMHO, with cap screws and limited access you will not be able to tighten some of the the screws. Tube bends get in the way. Some you can't get at straight on and since you can't see them anyway, why make it harder on yourself? Hex bolts allow socket access straight on or wrench access from the side. I bought new (shorter)bolts from Fastenal- I can look them up if you want.
Ted,
I think I will go with the bolts. If you have the part numbers of the bolts you purchased handy I'd appreciate that. You can PM me if you wish.
Old Jan 22, 2008 | 09:03 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
Yep... I had to use regular bolts (read hex head style) when I put on SW headers. It was a fun mod to do in the garage with the car on some jack stands.
Old Jan 22, 2008 | 09:07 PM
HammerZR1's Avatar
HammerZR1
Don't feel bad, that's what I'm doing this coming weekend. I wouldn't know how to work on a car on lift.
Semper Fi Brother
USMC 72-76 Det MAG-16
OV-10 Bronco Engine Mech
Old Jan 23, 2008 | 01:46 AM
95ZR1's Avatar
95ZR1
Originally Posted by HammerZR1
Ted,
www.fastenal.com Happened to be a store close to me.
M8x25 DIN151 Plain Hexagon Flange Lock Bolts
Wholesale Price: $1.09
Availability: In-Stock Item
Package Quantity: 1 (EA)
Qty: I got 30 - 16 a side and I reused 2 old bolts
Fastenal Part No. (Sku): 0161882
Manufacturer: Fastenal Approved Vendor
UNSPSC Code: 31161600
Category: Fasteners
Bolts
Flange Bolts
Also, Nick's header install write up is helpful on:
http://www.pnwzr1.net/PNWZR1.htm
And I love and identify with the commercial (valvoline I think) about how happiness is working under your car on cardboard over concrete. That's me!
Old Jan 23, 2008 | 02:20 AM
locobob's Avatar
locobob
Use hex bolts, if you use allen heads you will have trouble getting on them in the tighter spots.
Old Jan 23, 2008 | 08:23 AM
HammerZR1's Avatar
HammerZR1
Gotcha guys. I am going with the bolts, only makes sense.
Thanks for the replies.
Old Mar 3, 2008 | 10:14 AM
HammerZR1's Avatar
HammerZR1
I am in the middle of the header install on the '91. I can't get to the wire harness except to plug something in. There just isn't any room down there. So I need to extend the O2 sensor harness on the right side about a 1 1/2'. I can probably get the weatherpack connectors from NAPA, but advice on the wire size,type and any other information (especially the no-no's) on this would be appreciated.
Old Mar 3, 2008 | 10:35 AM
terryszr1's Avatar
terryszr1
if you are putting in new o2 sensors you can use the old ends from the old sensors . in the chiltons manual explains how to remove the pins. i used 12 gauge wire. i extended them8in. to get to the right connector i rmoved the right brace that the motor mount was connected to . the motor will NOT drop as its held elsewhere . hope this helps on the heat shields get a box of bandaids i used most of the box . hands felt like sushi
Old Mar 3, 2008 | 10:42 AM
HammerZR1's Avatar
HammerZR1
I am not putting in new sensors, just need to extend the harness on the right side. 12 guage is what I will look for. I know it isn't the normal stuff at Schucks.
Old Mar 3, 2008 | 01:59 PM
95ZR1's Avatar
95ZR1
FYI I also heard NOT to tightly seal and wrap either the existing O2 sensor wires or your extentions. There is some sort of air sampler tubing as a baseline you don't want to seal off or block.
Old Mar 3, 2008 | 02:35 PM
HammerZR1's Avatar
HammerZR1
Thanks a lot Ted. I found the connectors at NAPA and am waiting on a call from Marc Haibeck to verify anything else before I make these. I'll post more later tonight on what I find out.
Old Mar 3, 2008 | 04:02 PM
HammerZR1's Avatar
HammerZR1
I talked with Marc and there is no problem with extending the harnesses this way. He also mentioned that you can splice the wires, BUT, you can only use the butt connectors with no tape or soldering. If you do it that way you would more than likely end up with moisture problems.
Old Jun 18, 2012 | 04:31 PM
Luweegy's Avatar
Luweegy
Category: Fasteners
Bolts
Flange Bolts
Thanx for all the info.
Old Jun 18, 2012 | 07:25 PM
ZRWHAT's Avatar
ZRWHAT
I talked with Marc and there is no problem with extending the harnesses this way. He also mentioned that you can splice the wires, BUT, you can only use the butt connectors with no tape or soldering. If you do it that way you would more than likely end up with misture problems.
This is the exact reason I ran (2) extensions to my O2 sensors just for the sake of the weatherpaks and keeping everything dry as it should be, even with crimp connectors, just a matter of time before they start to corrode and become compromised.
Old Jun 20, 2012 | 12:21 PM
ZZZZZR1's Avatar
ZZZZZR1
John,
How soon we forget? See my write-up at www.pnwzr1.net.
I used the factory GM weatherpack connectors, sourced a a local GM warehouse. They worked great, look professional, are totally sealed up and will be problem free.
Good luck.
Old Jun 20, 2012 | 08:29 PM
Polo-1's Avatar
Polo-1
who is this guy from auburn........
missed you at the EWPNW Gathering
To Header Install
