C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Is this "physically" possible?
Old Aug 10, 2008 | 10:45 PM
dallas916's Avatar
dallas916
Default Is this "physically" possible?
Considering this car is well over 4000 lbs. and has a maximum of 370 hp at the crank....
http://www.maxperformancecars.com/in...d=2618&catid=5
OK...I don't know WTF is wrong with the link (it's not what I captured), but the car is a '99 Jaguar XJR (claimed totally stock) and the timeslip...if it's the same car...shows a 13.26 1/4 mile.
And he claims he's gonna can get into the mid 12's. Hmmmm
OK...link seems to be working now. My point is: how is it that the ZR-1 struggles to get into and stay in the mid 12-13 range (stock) with more hp and less weight..and far more tread on the ground. And, here's a luxo-sedan with all it's mass being able to run right beside some of us? Maybe we need to trade our 6-speeds for a good AT??
Old Aug 10, 2008 | 11:48 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Forget time, look at trap speed.
Old Aug 11, 2008 | 01:29 AM
willyszr1's Avatar
willyszr1
i agree with dominic , if you were to race him from a 15mph roll you would leave him in the dust so fast it wouldnt be funny. thats where these cars shine is a roll race . either that or go to a solid rear end setup so you can get after her off the line without fear 1/2 shafts flying all over the place.thats what i did with my black 90
Old Aug 11, 2008 | 07:02 AM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
Don't underestimate a supercharged Jag. The XKR and XJR are faster than you think they would be. High 12's would not be much of a strech.
777
Old Aug 11, 2008 | 08:44 AM
willyszr1's Avatar
willyszr1
dont mean to knock the jag but its still has lucas electrical system . which from my lotus days got the knickname prince of darkness . no way it keeps up with the zr1 .jmho
Old Aug 11, 2008 | 10:18 AM
dallas916's Avatar
dallas916
777
They are pretty quick for the weight they carry, but when you factor 4000+ lbs, smaller tires, no equalization of traction, and approx. 370 hp at their best it seems a little too fast. I can see low 14's, but not much less.
Old Aug 11, 2008 | 03:19 PM
Sihler's Avatar
Sihler
http://www.motortrend.com/roadtests/...eleration.html
Old Aug 11, 2008 | 06:57 PM
infamous's Avatar
infamous
...how is it that the ZR-1 struggles to get into and stay in the mid 12-13 range (stock) with more hp and less weight..and far more tread on the ground. And, here's a luxo-sedan with all it's mass being able to run right beside some of us? Maybe we need to trade our 6-speeds for a good AT??
You are looking at peak horsepower numbers, which tell you nothing about the torque curve for that engine. I didn't click the link or research the car, but I'd bet that engine has a meaty torque curve throughout the RPM range.
Also, traditional ATs always deliver power-on shifts because there is no discontinuity in torque such as when a manual clutch disengages. Sometimes an assumption exists that a manual transmission car is faster, but that's only because an intelligent driver can learn the best shift points. Now (probably 2005+) that automatic transmissions are smarter and have many more adaptive parameters, they can easily shift faster and at better spots in the RPM range. Look at the new Camaro, the automatic is faster than the manual and has significantly less horsepower.
Old Aug 11, 2008 | 07:19 PM
dallas916's Avatar
dallas916
The Jag uses a 5 speed AT that's not particularly beefy, and the V8 is only 4 liters. I sure wouldn't be drag racing the Jag very often as they are very expensive to repair and have a reputation for weaknesses in odd places (poor wheel bearings, lousy cam chain tensioners, strange things like rear view mirrors that leak, rear end bearing problems). But to the point of 1/4 mile times/speeds, it just seems to defy the power to weight ratio limitations.
To Is this "physically" possible?
