I have a 91 z that runs perfectly. I recently installed a Haibeck chip, and today I drove he car for about 25 miles and parked it for abouy 20 minutes.
When I started it again it went to full throttle like my foot was mashed to the floor. It felt like it was banging off the rev limiter fot 3 or 4 seconds till I could shut it down.
Tried an immediate restart and it did it again. Let it sit for an hour or so and had a normal restart.
A few hours later, same scenario. Drove about 15 miles, parked for 20 minutes, full power restart. Shut down, waited a few and had a normal restart.
98% of the time it starts normally. It goes to about 1800 rpm for 3-4 seconds and then settles down to 900
The engine still runs fine on the road from idle (rock steady) to redline.
Any thoughts?
Bot thats a strange one. How could it hit full throttle on its own, uses a cable.
My thoughts,mechanical link to your foot.Once on an 84 I used to own the cable for the cruise got bunched up at the servo and the throttle got stuck,Id take a look at that.
Something screwed up with the cruise control maybe ??
Disconnect it at the throttle body.
yea we don't have "fly-by-wire" throttle control.....there has to be a cruise control related issue. How else can the opening of the throttle blades be explained, which is clearly what has to be happening. If it was a sensor fault causing an "add fuel" condition why isn't the motor flooding due to lack of intake air....I doubt that the injectors could dump enough fuel to advance the rpm's that far without the T-blades opening to supply air?
I'd do a KOEO code search, both the ECM and the CCM to see if a DTC was stored...?...or maybe do a KOEO and go look at the cruise control diaphram to see if it is advancing the T-blades. JMHO:o
I spoke with Mark. He seems to think it's electrical, possibly a sensor or even a cold solder joint on the board. He went through a long theory of operation explanation on possible causes that I won't even attempt to try to explain here. Anyway, many starts later, all is still good.
Lets keep it simple here guys: If the prom was replaced, and then he had issues, it is likely the prom. It may well be the board as Marc says, but if you continue to experience issues, switch back to the old prom, reassess!
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Pull the prom out and make sure none of the connectors got messed up when the prom was installed. Then look at the receivers on the prom. If not change out the prom. Proms are very sensitive , just by rubbing the prom against some cloth will damage them quickly.
