C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Vacuum pump question.
Old Nov 3, 2008 | 04:34 PM
Z51JEFF's Avatar
Z51JEFF
Default Vacuum pump question.
Ive read that the vacuum pump for a Kodiak TopKick truck is basically the same pump for the secondary system on the ZR-1s,the only difference is the plug is different.Any info on this?Thanks.
Old Nov 3, 2008 | 05:36 PM
xlr8nflorida's Avatar
xlr8nflorida
Killing the Corvette Tax, one item at a time
Old Nov 3, 2008 | 08:00 PM
Z51JEFF's Avatar
Z51JEFF
I found it,Part #94669091.Price is $160.This is for the Kodiac truck pump.
Old Nov 4, 2008 | 10:53 AM
HammerZR1's Avatar
HammerZR1
Yeah buddy, that was a direct plug-in on my '91. P&G Chevy has them for a tad over $100.
Old Nov 5, 2008 | 01:33 PM
phrogs's Avatar
phrogs
Veteran: Marine Corps
Which means it is not correct for the 1990 ZR-1 the plug is different.
Old Nov 5, 2008 | 02:04 PM
HammerZR1's Avatar
HammerZR1
Johnny,
That's what I understand too, but I think Jeff has a '91 according to his profile anyway. Have you used these successfully on 90's, I think I have heard it being done before but can't remember if it was you or not.
Thanks for your service by the way.
Semper Fi Brother
John
Old Nov 5, 2008 | 03:11 PM
WVZR-1's Avatar
WVZR-1
The "service" connector is readily available and then it's a "service" pump to "ALL MY's"!!
If you're really **** you can use terminals on the wires rather than "cut & splice" then it's a "not to be seen" FIX!
12102747 for a connector.
If you're into cannibalization I believe the washer pump connector '90+ C4's, EGR solenoid 92+ C4's, door lock switches, '90+, mirror motors and many other locations share the connector. You could buy a couple metric-pak 150 female terminal, a couple seals and assemble your own connector. No visible "cut/splice"!
To Vacuum pump question.
